Old 10-02-2002, 09:30 PM   #1
Eagle1
Desktop Dyno Please
Could someone desktop dyno this combo for me.
350 SBC, .030 overbore
10:1 Flattop pistons
76cc stock heads, 9.5:1 compression
1.94int./1.50exh. valves
Cam Comp Cams XE256 12-234-2 with 212/218 degrees of duration, .447/.454" of lift, 256/268 degrees of advertised duration, and 110 degrees of lobe seperation
HEI distrbutor
Edelbrock Preformer intake
Carter Carb, 600cfm
Stock Exhaust Manifolds
2.25" dual exhaust with dynomax mufflers
And is there anything else I could do to make it have more power.
Eagle
77 C10 truck 355/TH350, 10:1 KB's, COMP XE256H, EDELBROCK PERFORMER, CARTER 600 CARB.
Eagle1 is offline   Reply With Quote
Old 10-02-2002, 10:08 PM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
It shows 292 HP at 5000k and 380 ft/lbs. torque at 3000rpm. It will be a good torque machine. Headers, etc will be required to get that HP up.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 10-02-2002, 10:27 PM   #3
bigjimzlll
bigjimzlll's Avatar
I come up with...263@4500 HP and torque 370@3000 rpm
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
