Roadtrip!
![]() Join Date: Feb 2003
Looking for frame parts
Looking for the rear frame rails (both sides) for a 69 short 4x4. About the last 12" or so. I am not sure if the 2wd coil spring trucks share the same rails or not. Shipping would be to 55744. Thanks
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Looking for frame parts
I think the 2wd rear frame parts should work.Are you needing past the rear crossmember? It's been a few years since I've had a 2wd 67-72 but I think the frame is the same past the last crossmember up a few feet till you get near the axle.The holes for the spring hangers will have to be drilled though.
![]() Join Date: Mar 2004
They are the same. I'm using the back section of frame on my 67 SWB 4x4. The PO had a flat bed on it and welded some other stuff to it. What a mess. I'm replacing a little in front of the last crossmember so i get it also. I don't want to bolt a new one in. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
Roadtrip!
Thanks for the info. Anyone cutting up a frame that is fairly clean towards the back?
4bynut, i have a similar situation, but with some rust thrown in for good measure!! You should have seen the channel iron bumper that was on this thing. Eric
![]() Join Date: May 2007
I have a 72 4x4 blazer frame for sale but i don't if its the same or not, maybe some one chime in with the answer.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Roadtrip!
Still looking...
1971 GMC 3/4 ton, 572 CID
I have a 72 C20 I'm going be cutting up the weekend of the 20th, send me a pic of what you need, you can have it if you pay the shipping
71 GMC 3/4 572 CID, 1988 GMC 1/2 2006 Saturn Vue "We always have parts left over on a job this size" |
Roadtrip!
Cool, thanks for the offer. I am looking for where the rear bumper would bolt on. About up to the rear cross member. The frame is not here at the moment, so it is tough to get a pic for you. Can you check the condition of the last 12-16 inches of the frame and let me know? Thanks, Eric
![]() Join Date: Aug 2007
I have a 72 c20 2 wheel drive frame im cutting up too and the frame is perfect. Let me know if you still need the rails.
Roadtrip!
It looks like i found some close to home from another board member. Thanks for the responses, Eric
