10-09-2007, 01:16 PM | #1 |
Carb Return spring kit info needed
Has anyone used this setup? If so, do you have a picture or better yet, instructions on how to install?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=013 thanks......
1997 GMC Sierra Ext 1965 Mustang |
10-09-2007, 01:44 PM | #2 |
Re: Carb Return spring kit info needed
I bought mine from Summit Racing and it came with instructions. Basically the bracket bolts to the carb base and faces forward. The bushings go in the large hole on the throttle arm with a bolt and another bracket. The springs attach to the bracket that bolts to the base and smaller bracket on the arm.
I don't have pictures with me, but I can take a few this evening and post them... It works "OK"-the biggest pain in the rear was getting the springs installed. Brian
1972 Cheyenne C10 Unrestored Original-3 Owner-RUST FREE Texas Truck Big Block-TH400-PS-PB-AC-AM/FM Radio |
10-09-2007, 01:51 PM | #3 |
Yes, if you could post pics, that would be great.......
10-09-2007, 01:56 PM | #4 |
I will get some on tonight...
Brian
10-09-2007, 09:19 PM | #5 |
Here are some pictures of mine. The carb is a Holley 1850-3 and the manifold is an Edelbrock Performer 2-0.
Brian
10-09-2007, 10:08 PM | #6 |
blood type; Retumbo
IMHO those are the best design for return springs ever. they dont wear out the shaft and are accurate. except I would mount the throttle cable to the large hole for a less touchy pedal. i had the same setup on my 80K20 with a highly modified 4776. it worked flawlessly.
10-10-2007, 04:34 PM | #7 |
Thanks Brian.....that really helps......
10-10-2007, 04:46 PM | #8 |
If you buy it and still need the instructions, I can fax them to you.
Brian
10-10-2007, 04:53 PM | #9 |
I already had bought it. I'll go by the pictures. If I need the instructions, I'll let you know.
thanks again......
10-10-2007, 05:45 PM | #10 |
Got it installed just now......Works great. Only hard part, was putting on the springs. They were a bear!!
10-10-2007, 05:51 PM | #11 |
Looks good. See...I told you they were a pain in the rear...LOL
10-10-2007, 05:58 PM | #12 |
My return spring broke this morning on the way to work and the revs shot up to 4K... I could tap it back, so I limped to Walmart (the only place I could find at 7:30...) and bought a small bungie cord and some duct tape. It was a quick fix, and worked great, but the dual spring setup has real appeal for me after the sound of my engine screaming.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
10-10-2007, 06:24 PM | #13 |
But, as they say.....If you can't fix it....duck it......
10-10-2007, 07:21 PM | #14 |
Man, that set up came out sweet, I have Lokar cables on mine, but I like the idea of my springs not wearing out my shaft, I'll have to put it on the todo list. Thanks for the idea
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-10-2007, 08:44 PM | #15 |
67-72 Addict!
Looks good Steve!. Where did you get it?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-10-2007, 09:16 PM | #16 |
Burnouts are therapeutic
I have the same setup bought it from summit I love it
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
10-10-2007, 09:44 PM | #17 |
10-11-2007, 01:41 PM | #18 |
Forth coming. I haven't finished getting all the parts on yet. I have completely changed the look of this engine. "70c10 " will not let me live it down either.
10-11-2007, 01:43 PM | #19 |
This is where I got mine. Fast shipping also.....
http://cgi.ebay.com/ebaymotors/CARB-...QQcmdZViewItem
