Old 10-17-2007, 09:14 AM   #1
manimal
manimal's Avatar
steering column interchange?
Would a steering column from an '80 4spd 2wd truck work in my '75 4spd 4x4? The wiring the same? Thanks in advance.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-17-2007, 09:40 AM   #2
tyjoja
Re: steering column interchange?
I'm not sure on your years, I was looking at putting a 75 tilt in a 73 and the wiring looked a little different but the switch that the wiring hooked to was interchangable. good luck.
tyjoja is offline   Reply With Quote
Old 10-17-2007, 10:34 AM   #3
wedgemon
wedgemon's Avatar
Should work fine.
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 10-17-2007, 10:37 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i believe that 83 or 84 is when they moved the wipers to the column and thats the change.. im not sure if you could switch off the arms and use the convert columns but there is a bigger hole for the wiper arm than the one with just the turn signal other than that there is no difference between two and four wheel drive columns
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-17-2007, 10:47 AM   #5
manimal
manimal's Avatar
Awesome,Thanks Guys!
-Lance
-Lance
Old 10-17-2007, 03:48 PM   #6
beaterC10
The 75 column should have a splined end, the 80 should be a double flat on the column shaft. This won't be a problem if you get the mating column coupling shaft. 84 was the first year for wipers on the column.
beaterC10 is offline   Reply With Quote
Old 10-18-2007, 01:05 PM   #7
bent
The master of disaster
bent's Avatar
if you really want to go trick find a tilt and tele colum from an old caddy i believe they came from and pull the wiring piece from youre column and put on that one i did thtwith my 80 that i had and i had more compliments on that then i did when the truck was like new
bent is offline   Reply With Quote
