Old 10-18-2007, 12:58 PM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
1972 Jimmy Rear end Question
Hey PAL's how are all you doing this Fine Morning?
I got a question as usual
I want to put Disk brakes on my Jimmy on the rear.
Is there a kit I can buy and where from and also whats the cost.
please advise. Thanks Forum Brothers. For the help in advance.
Angelse68cal is offline   Reply With Quote
Old 10-18-2007, 02:08 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 1972 Jimmy Rear end Question
Board member drink2mny works a company that makes them. http://www.blackbirdscustomtrucks.com/
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-18-2007, 11:01 PM   #3
Angelse68cal
Cochino_Racing_909
Is the any advantage using the 14 bolt 6 lug rear end with 9.5 ring gear .
Or is the 12 bolt just as strong?
Old 10-21-2007, 03:09 PM   #4
Angelse68cal
Cochino_Racing_909
I guess no opinion's on this 14 bolt 6 lug
Old 10-21-2007, 07:35 PM   #5
Mike C
Mike C's Avatar
The 14 bolt sf is quite a bit stronger than the 12 bolt bolt. I currently have one in the rear of my Jimmy, but it is 8 lug. My intent was to do a FF 14, but the complete 3/4 ton Suburban with 4.10 gears for $300 was too good to pass up!
I used my plasma cutter to remove the perches and shock mounts and then cleaned the tubes up with a grinder before TIG welding all the brackets in place.
I built an alignment jig and re-used the 14 sf perches which are for a 3 1/2" axle tube rather than the 12 bolts 3" tube. I did not use the suburban shock mounts but the original 12 bolt ones, which keep the shocks much better protected and fit my existing shocks. My jig positioned the spring mounts and shock mounts simultaneously. I used a protractor to match pinion angle to the factory 12 bolt.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
