11-03-2007, 01:53 AM | #1 |
Future TOTM Winner
New style rear axle?
I was daydreaming a little today...who here has installed a newer-style Chevy rear end (1999-200? model) in their K5 or K10? I figure rather than spend the time and money to rebuild my original and buy a disc kit for it, I might consider a whole different axle.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
11-03-2007, 06:59 AM | #2 |
Re: New style rear axle?
I've got a '98 3/4 ton 14 bolt FF rear axle with disc's in my off road blazer.
11-03-2007, 10:44 AM | #3 |
Future TOTM Winner
IIRC the 98s still had drum brakes, correct? I am mainly curious if someone was able to utilize the factory rear discs starting in 99 (on the 1/2 tons, a couple years later on the 14FF I think) and get the ebrake and what not to work properly.
Correct me if I'm wrong on the year models that I am spitting out, I'm getting old and forgetful!
11-03-2007, 11:11 AM | #4 | |
(was already installed when I got the blazer) No accomadation for e-brake either, sorry thought it might of helped. At least we know they fit under the trucks. |
11-03-2007, 11:15 AM | #5 |
so, are you saying they are a close enough fit (in length) to work?
11-03-2007, 11:23 AM | #6 |
Correct, they fit fine.
11-03-2007, 11:42 AM | #7 |
FirstGen spring perches are set inword about 1.5" from the location of a 73up 14ff. My 2005 Duramax has rear disk on it's 14ff. I could measure it but I would guess the spring perch is too wide for a 'bolt in" affair. I do belive the axel length is the same still but I am guessing...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
11-03-2007, 12:00 PM | #8 | |
There's always going to be custom work needed when you change em up. |
11-03-2007, 03:54 PM | #9 |
Cereal Killer
The rear axle in your Duramax isnt the good ole Corporate 14 bolt.....Im 99% sure its a AAM axle.
If I dont do it....somebody else will. |
11-03-2007, 04:16 PM | #10 |
Hmm I have no clue..at a glance it looks like a 14..after the glance I just ASSumed I knew what I was looking at...A BIG REAR END = 14bolt
11-03-2007, 05:02 PM | #11 | |
Future TOTM Winner
http://www.aam.com/index.php?s=25
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 11-03-2007 at 05:03 PM. |
11-03-2007, 05:17 PM | #12 |
I'm a poor spectator
Are van axles from the late 90's and 2000's still wider than truck axles?
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
11-03-2007, 05:20 PM | #13 |
Be careful now, on the newer style rears (half ton for sure, but not positive on the 3/4 ton and up), but the pumpkin is offset (not centered) to make up for the fuel tank between the framerail and the driveshaft. The drivers side a bit longer than the passengers side is. Other than that, with new spring perches near anything will fit!!
11-03-2007, 09:15 PM | #14 |
the new rear AAM axle like in my d-max is huge compaired to a 14blt axle it has a 12.5 ring gear in it and the axles are way bigger.
Earl 68 2500 4x4 GMC Burb |
