Old 11-03-2007, 10:14 PM   #1
aventur1
aventur1's Avatar
How does the shift indictor pointer........
1971 with tilt. Bought the indicator and as silly as it sounds I don't know how to install it? I removed the shift indicator housing, slid the end of the pointer into the angled base on the tilt section, but I don't understand how it fits into the indicator housing? I don't have a photo of my steering column.
aventur1 is offline   Reply With Quote
Old 11-03-2007, 10:27 PM   #2
powell72
powell72's Avatar
Re: How does the shift indictor pointer........
The part on the bottom that looks like a tooth clips under the housing to keep it in place as you move the cloumn. Am I making sense?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-03-2007, 10:35 PM   #3
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
I just bought the same thing and I could not figure it out either.This is why I love this site.
BigDaddyDave is offline   Reply With Quote
Old 11-03-2007, 10:43 PM   #4
aventur1
aventur1's Avatar
the shift idicator housing does not move?
Old 11-04-2007, 05:56 PM   #5
powell72
powell72's Avatar
aventur1, I sent you a pm, hope it helps explain better.
Chris
Old 11-04-2007, 06:18 PM   #6
aventur1
aventur1's Avatar
Thanks, got it!!!!
It's all good!
Old 11-04-2007, 06:27 PM   #7
BigDaddyDave
Hey no one sent me a pm,I feel dumb enough to get one. HAHA
Old 11-04-2007, 08:52 PM   #8
Richard Dobson
Shard with everyone, I gotsta know too.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 11-04-2007, 10:09 PM   #9
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
and here's another enquiring mind.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-04-2007, 10:43 PM   #10
aventur1
aventur1's Avatar
Ok, "Now this is for tilt steering"
I found out that the PO before me put the shift indicator on backwards. If you look at it there's 1 side that has a slot or a notch the lenth of the housing or close to. Then put the indicator lens back in. Well that's where the tab with the notch goes thats on your indicator pointer the bottom part. Now the long curve part of your indicator pointer fit's into the housing that moves when you select a gear. You may need to tilt your steering column all the way down to get it to fit in. Slide the floresent color tip in the top part where the letters are for the gears and hook the little tab in the cut out area on your indicator housing, then slid the long angle end into the housing that on the section that moves when you slelect a gear. Set the indicator housing down and tighten the screws.
Old 11-04-2007, 10:49 PM   #11
aventur1
aventur1's Avatar
Thanks to powell72 for the info!!
Old 11-05-2007, 06:14 AM   #12
aventur1
aventur1's Avatar
Big Daddy
Richard
68GM
Did you figure it out?
Old 11-05-2007, 08:37 AM   #13
BigDaddyDave
Thanks I do understand now.
Old 11-05-2007, 02:46 PM   #14
powell72
powell72's Avatar
Sorry guys, I sent the detailed explaination to aventur before I checked the thread and was too lazy to retype it all. I wasn't trying to withhold info, I swear!
Chris
Old 11-06-2007, 06:14 AM   #15
aventur1
aventur1's Avatar
It's all cool,powell72, were getting ares fixed now with your help!
Mine works great! Even got my light to work!!
Old 11-06-2007, 06:56 AM   #16
1972Ryan
Where can you get one of those, Mine is broke on my tilt column.
1972Ryan is offline   Reply With Quote
Old 11-06-2007, 07:16 AM   #17
aventur1
aventur1's Avatar
I ordered mine from the Truck Shop. www.truckandcarshop.com Part number 70-06901 70-72 $4.00
