WTB vacuum gage
I have a 67-72 instrument cluster with everything but a vac gage. Are they available?
Richard Dobson |
Re: WTB vacuum gage
I got one. PM me and I'll tell you more.
"Trucks with Class"
![]() Join Date: Jul 2000
Re: WTB vacuum gage
You will need the "changeover kit" with several new components to put a vac in your cluster. Check out the vendors's or catalogs to see what is involved.
Re: WTB vacuum gage
PickMup, I looked in the YearOne catalog and I don't see any reference to a vac gage adapter or whatever. Do you have to make changes to the circuit board on the instrument cluster? What do I need to make to include a vac gage? Thanks
Richard Dobson |
Re: WTB vacuum gage
I have PM from a couple of guys that have gages but, I don't want to commit myself if I can't make the changeover to add a vac gage.
Richard Dobson |
Re: WTB vacuum gage
you have to have the gauge, the tin insert for the guages to show through and the backing plate that holds both the oil guage and the vac. guage. you do not have to have anything else other than your guages and if you are running factory tach ,that particular printed circuit
![]() Join Date: Aug 2004
Re: WTB vacuum gage
You also need the right plastic lens.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
71 Chevy
Re: WTB vacuum gage
I did the conversion, what you need is the lens, vac gauge, and the front tin that has the correct hole. The rear or back tin doesn't matter they are all the same, except for the tach and non-tach setups. The same little metal plate that the oil gauge is bolted to can be used for the vac gauge as well.
So what you need is: 1. lens 2. vac gauge 3. the front tin that has the correct hole.
71 C10 72 C20 62 Chevy II 2DR HT |
| Bookmarks |
