Old 11-15-2007, 12:39 AM   #1
muddpile
muddpile's Avatar
Seat Belt bolt holes?
I need a small favor from someone. I had to replace so much of my floor, that somewhere in the shuffle I forgot to put in seat belt holes. I have the ones for the center belt and inner buckles, but I need the ones for the outer driver passennger parts. Can someone please measure from the back of the cab wall and from the door weatherstrip or something for me please? Thanks!
muddpile is offline   Reply With Quote
Old 11-15-2007, 06:47 AM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: Seat Belt bolt holes?
The seat belt bolts to the rear cab support. There is a welded nut on the front edge of the support. Look underneath the floor and punch the hole from the bottom.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 11-15-2007, 10:52 AM   #3
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
that's how I did my last set.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 11-15-2007, 04:08 PM   #4
muddpile
muddpile's Avatar
I replaced the floor and the rear cab supports, so right now there is nothing... The nut was actually broken off originally from rust.
Old 11-15-2007, 04:19 PM   #5
BACKYARD88
BACKYARD88's Avatar
OIC. If no one else does it I'll measure mine when I get home.
-Mike Owen-
Old 11-15-2007, 06:41 PM   #6
BACKYARD88
BACKYARD88's Avatar
OK. Mine are 6 3/4" from the back wall and 2" from the inside of the weatherstrip flange, both sides.
-Mike Owen-
Old 11-16-2007, 12:46 AM   #7
muddpile
muddpile's Avatar
Thanks man! That's in the area I figured, but now I know for sure. Carpet will go in ASAP now.
