Old 10-09-2002, 09:45 AM   #1
RodC
RodC's Avatar
Preventing Surface Rust while working
You guys oughta go over to paint and body now and again
Ok guys, I have my bed apart and I am welding up some holes. If this project is going to take a few months and my panels are going to be stored in a cold garage, how can I keep it from rusting? The weater may not get warm enough to get out the ole paint gun to shoot primer. (I dont want to spray in my garage open flame heat not good ventelation etc )
I dont like the Idea of spray can primer because I would just have to remove it when I get ready to shoot the real stuff.
Do I just let it rust then remove it? Seems like this would be the same effort as the spray bomb primer.
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 10-09-2002, 10:07 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I have the same dilemma but decided the spray bomb is fine since it is pretty easy to remove and it lets me know when I have the body work about where I want it. I can never tell if it is just right until I have put a coat of something on there and a light to see the high and low spots.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-09-2002, 10:23 AM   #3
RodC
RodC's Avatar
I may go with spray bomb. Has any one tried this from eastwood:
Metal Wash 7 Ounce
Item No. - 10120
Promote topcoat adhesion on bare metal. Metal Wash cleans and protects in one quick step without using harsh or flammable solvents. This non-toxic compound removes grease, oily preservatives and contaminants, leaving behind corrosion inhibitors that prevent flash rusting for up to 3 weeks and promotes adhesion of paints and powder coatings. Ideal for the preparation of any base metal, including freshly abrasive blasted parts (even after blasting, surface contaminants remain). Economical to use, metal wash is a dry compound that can be mixed with hot water in whatever quantity is needed (makes 7 quarts).
Regular Price: $9.99 Buy 3 or more Pay Only: $ 8.99 ea.
This item is in stock.
http://www.eastwoodco.com/email/defa...geName=default
Rod Childers
'71 C10 Stepside
Old 10-09-2002, 10:32 AM   #4
the-wreck
There is a product called Rass o Nil. It is made for bare metal prep. It's a rust converter and bare steel prep. It covers the surface with a cloudy (dry) coating that prevents rust from forming. It also works like an ething compound to allow better paint adhesion. Only drawback is it cant be used with etching primer. Its compatable with all other primers. I have used it and its great. No sirface rust on bars metal over months
the-wreck is offline   Reply With Quote
Old 10-09-2002, 05:46 PM   #5
CraigS
Rass0Nil changed its name to Picklex 20. Works great.
72 GMC K20, 454, TH350
00 GMC Yukon
66 Ford Bronco
CraigS is offline   Reply With Quote
Old 10-09-2002, 06:57 PM   #6
photoglg
photoglg's Avatar
I used Permatex Rust Treatment (was called Extend) on my tail gate after it was sand blasted it has been sitting in garage for 4 months and has not rusted as yet. I live at the beach and every thing rusts here.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 10-09-2002, 08:03 PM   #7
RodC
RodC's Avatar
Picklex 20 sounds like a good Idea, but dont you have to spray it on? Which is what I wa tryin to avoid
Rod Childers
'71 C10 Stepside
Old 10-10-2002, 08:16 AM   #8
Jwill41
Jwill41's Avatar
I used the spray can primer on my bed last summer. I had to do all the body work(even painting) outside. i did not remove or use any other primer before painting. This truck is kept outside and the paint is in perfect condition. At hte link below there are pictures of this painting being done in my backyard. This was my first attempt at body work so I really dont know what i am talking about. LOL.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
