Old 12-12-2007, 07:33 PM   #1
pickupman
pickupman's Avatar
Transfer Case Oil ?
Does the transfer case on an automatic truck take auto trans fluid or gear oil? I cannot remember.
Thanks,
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 12-12-2007, 07:47 PM   #2
1969 GMC
1969 GMC's Avatar
Re: Transfer Case Oil ?
gear oil. the t-case gets atf in it when the adapter seals go bad.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-12-2007, 07:48 PM   #3
jamie72
jamie72's Avatar
what he said..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 12-12-2007, 08:03 PM   #4
pickupman
pickupman's Avatar
ok thanks, just was thinking I had taken some apart from automatics that had all trans fluid in them.
Old 12-12-2007, 08:44 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Although not ideal, would ATF still work in the transfer case?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 12-13-2007, 03:19 AM   #6
Mudder
Mudder's Avatar
I use 10w40 in my 203 and always have with no problems.
Mudder is offline   Reply With Quote
Old 12-13-2007, 05:37 AM   #7
Blazer1970
Blazer1970's Avatar
GM started to spec ATF for the NP205 behind automatic trannies in later years. ATF will work just fine in a 205.
Blazer1970 is offline   Reply With Quote
