Old 01-05-2008, 12:24 PM   #1
chevy one
Chevy One
6 Lug Rotors, Where To Buy?
Anyone know where is the best buy for the six lug rotors to fit 71 spindles? The best price that I have found is around $89 a piece.
Chevy One
67 1/2 Two-on-the-Floor
67 Nova 2Dr Sedan
03 Monte Carlo
I'M NOT OLD, JUST A CLASSIC!!!
chevy one is offline   Reply With Quote
Old 01-05-2008, 12:28 PM   #2
lilred67
lilred67's Avatar
Re: 6 Lug Rotors, Where To Buy?
early classic enterprises is where i bought mine
lilred67 is offline   Reply With Quote
Old 01-05-2008, 01:04 PM   #3
71 super
71 super's Avatar
GMC pauls has good prices on them as well as braided hoses etc. if you are going away from stock.
71 super is offline   Reply With Quote
Old 01-05-2008, 04:57 PM   #4
chevy one
Chevy One
71 supper,
I am converting to disk up front. Found a 71 junkyard dog that had all new upper/lower ball joints, I/O tie rods, calipers and new five lug rotors. I robbed all, plus the spindles and backing plates. I want to keep the six lug being to costly to buy new 5 lug rims at the moment. Will GMC Pauls rotors fit the 71 stock spindles? Thanks.
Chevy One
67 Nova 2Dr Sedan
03 Monte Carlo
Old 01-06-2008, 04:12 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Go to your local parts store and ask for 91' C2500 rotors. I've heard they fit. Also make sure your loaded calipers fit over that disc. If not, take them back for a refund!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-06-2008, 05:11 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Originally Posted by chevy one View Post
71 supper,
I installed ECE 6 lug rotors on a 71 suspension. I swapped a complete 71 disk suspension to my truck (67), but after being unable to locate a cheap 71/72 5 lug rear end (cheapest I found was $250) I bought the ece rotors. I got mine cheap from a board member who swapped from 6 lug to 5.
I've read so many "this new truck rotor should work" threads but have yet to see a single definitive post that says "YES! I installed XXX rotors on my truck with XXX year parts and everything bolted on!"
I'd love to hear from someone who's actually done it?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-06-2008, 05:40 AM   #7
71 super
71 super's Avatar
Yes the rotos from GMC Pauls fit onto 71 spindles with no problem, I used a 71 spindle on a 69 that I am building to sell. The 71-72 calipers fit as well, only problem that I had (not really major) was 68-70 center link (already had painted and ready) does not work with 71-72 tie rods so be sure you get the center link from a 71-72. As far as the new model light duty 3/4 ton 92 six lug rotors- yes the are similar, no they do not work correctly. The bearings, races and seals are exactly the same as our trucks, nfortunately when installed they have about 1/8th positive offset at the caliper different from ours. The only way to get the caliper to fit would be to use organic pads and grind them down until the caliper slides onto the rotor. I for one don't like that idea, but the cost for those rotors is cheap, $40 each ,so it may be tempting. I now that there proposals that the difference could be made up by using 92 calipers- they WILL NOT fit. Buy from Pauls or ECE andbe done this is not something to monkey with- I tried based off of info I found here and also had access to parts books and employee discounts when I attempted this. The later rotors DO NOT FIT AS THEY SHOULD with what our trucks have in place stock. Good luck.
Old 01-06-2008, 05:50 AM   #8
70GMCer
70GMCer's Avatar
Excuse the minor hijack, but, do you know if those rotors would work on 73/87 spindles?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-06-2008, 06:08 AM   #9
71 super
71 super's Avatar
As far as I know the 73-87 spindles are the same as the ones found on our trucks- unless it is a heavy 1/2 ton then there is some difference in rotors and calipers
Old 01-06-2008, 06:42 AM   #10
chevy one
Chevy One
71 super,
Thanks for the info. I do know you have to use the 71 outer tie rods to mount to the spindles. Did not know that the inner rods would not mount to the 67 center link, did not rob it at the time, guess have to go back to the bone yard in the snow and muck now. Is it possible to use inner tie rods for a 67/68 to mount to the center link? I think the rotors from GMC Pauls are around $85 + shipping. This looks like the best route to go unless I have a machine shop fill and redrill the 5 lug to a 6 lug. Dose GMC Pauls rotors come with new bearings and races?
Chevy One
67 Nova 2Dr Sedan
03 Monte Carlo
Old 01-06-2008, 07:15 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a FAQ thread that may have some answers.
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-06-2008, 09:04 AM   #12
71 super
71 super's Avatar
The rotors have races installed. The 67-68 inner tie rods can be used but it requires a special sleeve to adapt the threads, there is a difference. I found it best to get all of the same stuff (year) so when the truck sold the new owner would not have to search forever to get the stuff to fit. I know it sounds crazy but it makes more sense fo me to do it this way.
Old 01-06-2008, 03:27 PM   #13
STP67-72
STP67-72's Avatar
The best way is to use all of the 71-72 stuff. Centerlink, tie-rods, hoses, hard lines, ball joints etc. If you use the 67-70 centerlink and inner tie rods.You need to order special adjusting sleeves and 71-72 outer tie rods. I just ordered sleeves from CPP. You will have to do some adapting to make your 71-72 hoses work.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 01-06-2008, 04:10 PM   #14
slammed1
1972 Chevrolet SWB
slammed1's Avatar
I have seen a few places even carrying conversion rotors with 6 lug for either stock or dropped spindles,McGaughys,Early Classic,Performance Online and others have numerous options.........check them out.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
