Old 01-06-2008, 03:18 PM   #1
sb69chevy
sb69chevy's Avatar
Changing out stock tank w/ new one ?s
Okay, got my new tank, sending unit, etc and will be doing this tomorrow. Couple of questions, though:
1. Does anything need to be put on the new filler grommet for sealing purposes?
2. I've read about making sure the sender is sealed well. Any tips/tricks to making this happen?
Thanks. sb
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 01-06-2008, 03:35 PM   #2
huero
1969 Short, Fleet, and Beat
huero's Avatar
Re: Changing out stock tank w/ new one ?s
Thanks. sb
Are you talking about the o-ring that gets sandwiched between the sender and tank?
huero is offline   Reply With Quote
Old 01-06-2008, 07:21 PM   #3
sb69chevy
sb69chevy's Avatar
Yeah, some had mentioned to make certain this gets a good seal. Also curious if the grommet on the cab needs any sealer or if it seals itself and doesn't allow moisture into the cab.
Old 01-07-2008, 06:52 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Lube the O-ring for the sending unit.It should be tight when you turn it.Be careful it doesn't bunch up or get pinched. On the grommet you will need
1.LOTS OF PATIENCE
2.Lube-I think most use dish soap.
3.A couple cold ones to celebrate with once you complete this task.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
