Old 01-20-2008, 10:07 AM   #1
skokie
skokie's Avatar
Truck wont start
Its been 2 months since I started it and today when I went out to start it nothing. I checked the battery and had 12.20 volts. Put the meter on the batter and when I turned it over it didnt move. Ignition switch was replaced last time I started it. The under dash harness is new as well as the engine harness. Distributor is hei and I checked that and its good. The harness I have from M&H has the hei wire running into the engine harness. What else should I check?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-20-2008, 10:10 AM   #2
67CHIP72
STOLEN
67CHIP72's Avatar
Re: Truck wont start
Is it getting fuel to the carb?
In Search Of
67CHIP72 is offline   Reply With Quote
Old 01-20-2008, 10:11 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Grounds. Anywhere you should have one, and everywhere they are supposed to be. Make sure they are all "good" and clean. Rust (aka corrosion) is an insulator, if it is trapped between what should be grounded and that which is the ground.
Member Nr. 2770
Old 01-20-2008, 10:37 AM   #4
skokie
skokie's Avatar
I got a strap on each valve cover, battery is grounded to the block, strap to the rad support to frame, and there is another one out back.
68 build thread
Old 01-20-2008, 10:48 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I doubt the battery is the problem but a fully charged battery should read 13.3 volts or 2.2 per cell.I agree with the grounds and would also check the solenoid.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-20-2008, 11:18 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Did you try shaking the shifter... pulling it all the way up into park?
Old 01-20-2008, 11:43 AM   #7
skokie
skokie's Avatar
Ooops forgot to out that part into the first post. The column is not installed. Also I dont have a neutral safety switch installed either. But now that you mention it Andy its acting like it would act if you had it out of gear with a neutral safety switch install. Also another thing I noticed I turned my heater on and when I turn my key like I am going to start it the heater does not come on. Is there a wire I could put my meter on to see if I am getting power with the ignition on?
68 build thread
Old 01-20-2008, 12:18 PM   #8
skokie
skokie's Avatar
Let me clarify something here. When I say it wont start I mean it wont turn over. I reread the post and noticed that I was not very clear. Its been that kind of day
68 build thread
Old 01-20-2008, 12:22 PM   #9
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Try pulling the cables and cleaning them until shiny lead on posts and cables. Then throw a charger on it for a minimum of 6 amps 2 hrs or 2 amps 4 hrs, check voltage. regardless of voltage amps is what starts your engine. You can trickel 12 volts through a poor connection, and it wont start your engine.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 01-20-2008, 12:24 PM   #10
skokie
skokie's Avatar
Battery is on a charger now. After I unhooked it I cleaned the posts and the cables themselves.
68 build thread
Old 01-20-2008, 12:30 PM   #11
skokie
skokie's Avatar
One more thing to add. In the cab all the lights work. Dome light, head lights, parking lights etc.
68 build thread
Old 01-20-2008, 12:33 PM   #12
Longhorn Man
if there is no column, then you need to put a jumper wire in the 2 purple wires that plug into the neutral safety switch
Old 01-20-2008, 12:34 PM   #13
skokie
skokie's Avatar
Would hooking up the neutral safety switch work? I have it off of the column.
68 build thread
Old 01-20-2008, 12:43 PM   #14
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
That would probably work if it's in the proper position . I would just jumper the purple wires . Did your truck start before with all of this stuff removed??
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 01-20-2008, 12:45 PM   #15
Longhorn Man
yeah, you can plug it in and move the tab all the way to the left (as the switch is mounted in the truck)
Double check to make sure the truck is in park if there is any question at all in your mind.
Old 01-20-2008, 12:46 PM   #16
skokie
skokie's Avatar
Yeah Andy that would not be good if it lurched forward now would it That has been checked and it is in park.
68 build thread
Old 01-20-2008, 01:34 PM   #17
skokie
skokie's Avatar
Ok I stopped what I was doing to say Longhorn man nailed it. The neutral safety switch was the problem. I took the one off of my column and plugged it in and it worked. It now turns over. Now to get it running
68 build thread
Old 01-20-2008, 10:39 PM   #18
Old Chevy Mech
Keepin it runnin!
Good deal!
1970 K-5 4X4 Blazer
