Hydro assist steering
Anybody done this? If I have manual steering now, I need a full power setup even for the companies that rebuild em? The assist is run from the same power pump as the regular power steering? Does the ram get power through the power steering box? Couldn't you get get a power steering pump and run the ram right off that?
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
I do everything twice, so what
Location: To the Right. One may go as far to say WAY to the Right
Re: Hydro assist steering
you need a orbital valve for full hydrolic stearing
edit: you can use your p/s pump off your motor
www.hilbillytruckpulling.com Last edited by hilbilly; 02-01-2008 at 01:35 AM. |
on my jeep the ram gets power from ports on the steering box. If you ran the power right off the pump, youd have no way of metering the amount of fluid to the ram. thats why its ran off the box.
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
#4 | |
the orbital valve is what meters the fluid. Are we talking about two differnet set ups?
www.hilbillytruckpulling.com |
full hydro vs hydro assist. My setup is hydro assist. I have a steering box and pitman arm and draglink and a hydraulic ram mounted on the axle housing which pushes and pulls the tie rod. It draws fluid from the ported box in relation to steering input.
I'm full hydro. pump to orbital valve/steering wheel down to the ram mounted on the axle housing. no steering box.
i thought about running full hydro, but i was afraid of the street manners, such as return to center. But its not like the death trap (jeeps nickname) is streetable anyways.
my stuff only see's the pavement when its on a trailer heading to the track.
So best bet for mostly street driving is to swap to a power box and that would control the ram?
I think so. AGR and Power steering customs make good stuff
yep
http://www.pscmotorsports.com/
Good info and great products. I have the setup but I need to mount my ram still....too damn busy with life ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#13 |
The early trucks have a spool valve on the tie rod that hooks to the steering box, like old mustangs, vettes, and early 60's gm cars. This way you keep the manual box and just add power assist. The ratio is still dead slow, 8 turns or so lock to lock.
