99 and up 2wd 6 lug front crossmember swap into a 67-70 c10
Does anyone have any opinions on a 99 and up 2wd 6 lug front crossmember /suspenssion swap into a 67-70 c10?
These 99 and up parts are cheep, cause there metric I think. |
Happy to be here
![]() Join Date: Mar 2000
Re: 99 and up 2wd 6 lug front crossmember swap into a 67-70 c10
Are they cheaper than 73-87 GM truck parts?
Two totally different frames, and the 88+ trucks dont have bolt in crossmembers.
Insert Title Here
what about just cutting the frame off at the firewall and welding the new clip on to your old frame
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Junior Member
the geometry is better on the 63-87 trucks. I would stick with that stuff.
60-66 Nut
![]() ![]() Join Date: Mar 2007
I found this in the FAQ a while back http://www.67-72chevytrucks.com/vboa...ad.php?t=35042
I got lucky and got a complete front suspension (actually the frame was cut behind the cab) for cheap, and the 6 lug rotors I found to be real reasonable at Schucks, and I also have the lower a-arm. This is what I'll be doing to my '66 Suburban this summer
It is also something I have thought about. After delving into many different years of trucks, the '99 and newer GM 1500 2wd trucks have great clearance, rack & pinion steering, and will lay a huge wheel and tire combo. Let's not even mention the amount of off the shelf big brake kits available for the newer trucks. My truck is a square body 5 lug so something to take into consideration is the need to swap to a 6 lug rear axle and brakes should anyone decide the newer front clip is the way to go.
As for that Tony guy...he has no idea what he's talking about. His chick told me so one cozy night... ![]()
Cleverly disguised as a responsible adult... |
Junior Member
One Cozy night....??? Must have been my girlfriend.... My wife has been pissed off since kid #1
Tony I am just giving you a hard time because I love you. I can say that with a straight face because you are a special little man to me...
