4x4 rear disc brakes
I know you can put disc brakes on rear of a 2 wheel drive. Is there a rotor and caliper that can be used as a rear brake setup for a 4x4?
I bought the impala/caprice caliper brackets but have since decided to make the truck a 4x4 using 87 subrurban suspension. Anybody try this or have any thoughts?
72 LWB
Re: 4x4 rear disc brakes
Which axle are you going to use? There are a lot of kits that will work.
If you run a 14FF rear end, the swap is fairly easy. Here's a really good writeup:
http://www.pirate4x4.com/tech/billav...b_disc_brakes/ |
![]() Join Date: Jan 2003
Get ahold of hilljob26 he set me all up with mine. There easy and sweet.
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
actualy i beleive that the axles are 10 bolts. i havnet got under it and looked. Im thinking that that year of suburbans use that stock
72 LWB
I bought my adapters from ruff stuff specialities, but mine is a 3/4 ton with a 14/FF. I was able to use the same calipiers that are on the front.
I was impressed by the quality for the price, $ 64 shipped to my house. http://www.ruffstuffspecialties.com/catalog/index.php
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
The 14 bolt ones are way easier than the the 12 bolt ones.
5 lug look at town cars 6 lug look to 4wd front roters and caliper brackets
common sense isn't so common anymore |
![]() Join Date: Dec 2004
this is what my setup looks like,i do not make the brackets anymore,but i sell the templates,pm me if you are interested
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
![]() Join Date: Feb 2001
Here are mine and everything is used from a front 44. the donut (spacer) has to be purchased or made.
| Bookmarks |
