OPS GUY
engine cleanup...
my engine is so covered in oil that i would really like to clean it up. Any ideas with out having to take out the engine?
great southern land
Re: engine cleanup...
get a can of degreaser and spray it on scrub with a little brush on hard spots then hose off... just blow all watter out of low ares on the engine an avoid getting the electrics wet.
go get some castrol super clean, its in a purple bottle. spray your engine with it and let it soak for a while(untill it dries) then go back and spray it down again, then wash the engine with a high presure washer.
1975 C-10 Silverado LWB
shouldnt you cover the carb with a plastic bag or something first? Its ok to just go through with a pressure washer?
1975 LWB C-10 Silverado - Stock - "BIG 10" - 4 Bolt 350 "Brand new" 1200mi - THM-375 "Brand new w/trans cooler" 5000mi 1995 Ford Lightning - Bone Stock - 351W - Vortech?? |
On a budget like Fred Sanford
^^^Yeah, you don't want to get any water down the carb....a plastic bag or a few oily rags will do the trick.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Cruzzzn' Vet
Dark Heart Motorsports
plastic bag the carb and dist...
then seafoam the entire motor inside and out (yes you can run it through your engine too... thats the great thing about seafoam). change oil, after washing down the exterior of the motor and you should be good to go.
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
Plays with trucks
I use the Super Clean and one of those $100 1300 psi pressure washers. Just cover the carb and dizzy, If it's really thick, clean it while the engine is warm (but not HOT).I use a garden sprayer to spray on the cleaner ( no pumping on a trigger and it's all-position) May take 2 rounds, may have to scrub/scrape the extra heavy stuff, but it's worth it to be able to work on a clean motor.
Gary My Dad's Old Truck 1985
Robert Olson Transport
![]() Join Date: Oct 2002
ive used a pressure washer on mine , several trucks and its always worked well.. you can use any decent commercial grade cleaner even gunk is good.. like others said cover the carb and distributor well and ya should be good to go
| Bookmarks |
