Old 03-02-2008, 05:02 PM   #1
Swed-Chevy
Swed-Chevy's Avatar
Mechanical oilpressure gauge.
Hi,must I connect the gauge hose to the "original oil pressure sender" location or is it some other place on the engine it is possible/easier to mount it ?
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E.
GMC Sierra Custom C1500 1983.
Oldsmobile Dynamic 88 -65.
Volvo V70 -02 and BMW 523i T -99.
Harley FXDF -08 and Harley FXDB -10.
Honda Dirtbike Dominator -97 and a couple of tractors.
Swed-Chevy is offline   Reply With Quote
Old 03-02-2008, 08:13 PM   #2
ChevyTech
Re: Mechanical oilpressure gauge.
You should also still have the original sender on the engine because it has a fuel pump power supply circuit through it.
The fitting that the original sender screws into is not very strong and adding more fittings to that combination could be troublesome.
There should be a plug in the block above where the oil filter area on the drivers side of the engine that would be a good place to connect to.
Old 03-03-2008, 09:34 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
The reason that most oil pressure senders and gauges are attached to the top of the engine, IS so that you can see that you have oil pressure throughout the engine. It would be the weakest point at the top and away from the filter housing.
piecesparts is offline   Reply With Quote
Old 03-03-2008, 09:45 AM   #4
get me on the road
No Matter What.
get me on the road's Avatar
Right here. Where that brass tube screws in. It should have a allen wrench plug in it.
Currently own:
89 Chevy Silverado
Previously Owned:Starting with my first vehicle
86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10
get me on the road is offline   Reply With Quote
Old 03-03-2008, 07:38 PM   #5
Swed-Chevy
Swed-Chevy's Avatar
Thank,s boys.Looks like an hexagon bolt just above the oilfilter adepter on the pictures. Is it this plug I can use ?
Old 03-03-2008, 11:48 PM   #6
ChevyTech
Yes
Was this also a test to see if we could figure out the photos are upside down?
Old 03-04-2008, 07:38 PM   #7
Swed-Chevy
Swed-Chevy's Avatar
Yes
Thank,s. Sorry about that,hope the pictures look better now.
Old 09-19-2016, 06:16 PM   #8
Joe C
Hi, New to the forum but I also want to install a mechanical oil pressure gauge on my 1993 4X4 2500 454. Is there any where on the block to connect a gauge other than where the stock sender is located ? Thanks for any help. Joe.
Joe C is offline   Reply With Quote
Old 09-19-2016, 09:05 PM   #9
ChevyTech
There is one at about the same spot as the small block V8s just above the oil filter.
Also on the drivers side of the block, at the very front of the block, at the bottom of the block, just above the oil pan, on the 7.4 liter (454CID)
Welcome to the board!
Old 09-19-2016, 09:53 PM   #10
Joe C
Smile Re: Mechanical oilpressure gauge.
Thanks, The reason I was looking for another place to connect the gauge because I was told that the stock sender has something to do with the fuel pump. Can I bypass the stock sender or is that a bad idea ?
I recently retired and bought the truck to haul stuff but now I want to fix it up a bit besides it gives me something to do for fun. Tinker around in the garage
Old 09-20-2016, 10:11 AM   #11
ChevyTech
You're welcome!
Leave the stock sender in placed.
The stock oil sender does have a fuel pump circuit through it, which is a redundant power supply to the fuel pump.
Congratulations on retiring.
Old 09-20-2016, 05:38 PM   #12
Flying Hamster
Flying Hamster's Avatar
Other option is to put a tee in where the stock sender goes, and hook both the new gauge and the factory sender into the tee. Then they are both seeing the same thing, and no lines down at the bottom of the engine to get hung up and broken.
Flying Hamster is offline   Reply With Quote
