what dash clusters will fit a 77?
Hello all,
I was wondering which dash clusters I could use on my 77?? Mine finally went out.From what I gathered so far I know I can't use a 73-75 and there looks to be something different for 76-77.I'm confused. All I want to work is the speedo and the gas gauge. i'm not concerned about the others since I have aftermarket ones.Will 80-87 work since those seem more abundant?? Also has anyone had their speedo bounce and make a bell ringing sound?? [I thought my gremlin took up music] Thanks in advance |
#2 | |
Re: what dash clusters will fit a 77?
it needs to have a volt gauge and mechanical oil pressure gauge. only found on 76-77. All this according to this website:
http://73-87.com/7387garage/interior...achometers.htm im not sure if a speedo and gas gauge from a different year would work or not though. I dont think it would because of the circuit on the back. I have a 76 and am looking at buying a tach cluster Quote:
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com
Last edited by N2TRUX; 03-07-2008 at 09:35 AM. Reason: Please do not solicit sales. |
Is the problem just because of the volt and oil gauge? I'm not even going to hook those up.
Has anyone swapped in a newer cluster in an older truck? The pic on that site for a 77 cluster doesnt look like the same font as mine for the #'s. I'm gonna have to check that out.[maybe I have a newer one in there now??] All I need is the fuel and speedo to work. |
Im not sure. Like I said, all i know is what is on that website. I am pretty sure it is the 73-87 website guy that knows alot about these things. maybe he can chime in.
HI, the needle bouncing and bell ringing sound sounds like maybe a bad speedo cable where it binds and then lets go, binds and then lets go... it will bounce the needle all over and can make a dinging. It will do it to the next one too if that is what it is.
Hope it helps... Bill |
I just put in a new speedo cable in and it's still bounceing. Mainly over bumps in the road.Needle keeps hanging up too.
| Bookmarks |
