Old 10-26-2002, 07:57 PM   #1
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Heater upgrades?
I have a standard non a/c truck that I would like to make the heater work a little better is there any tricks out there to do? Saw a switch at GMC Pauls for fan speed? Mine seems to have poor air flow? Is that normal? I am use to my 98 Ford work van that the heater kicks @$$ in!
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 10-26-2002, 08:17 PM   #2
jasonrog
jasonrog's Avatar
I bought my 71 from my brother in law. He said he put in a heater core from a ford. The largest one that would fit. Up here in the north, I can ride around in my truck in a t shirt when its -40 outside! It's great
jasonrog is offline   Reply With Quote
Old 10-26-2002, 10:26 PM   #3
imaindianoutlaw
GMC SHORT FLEET F/S
Wish I knew what core that was! I would also like to increase air flow! I should pull my motor and see what the blower wheel looks like?
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
Old 10-26-2002, 10:47 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Yea, check the squirl cage on the fan. Mine was cracked and broken. It looked like the mice were chewing on it. Also i had leaves in the heater box that were obstructing the flow and cracked and broken defroster ducts. I got good heat now. It will make your feet sweat! Also put anti-seize on your wire going into the control cable so you dont break off those heater control leavers. They always break off.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-26-2002, 11:36 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Heres a good tip on this subject...the heater blower moter from an older caddy is a direct bolt in, and blows a little harder.
Old 10-26-2002, 11:53 PM   #6
chewed 71'er
Yeah, typical in these trucks, check your heater box, might be loaded with trash. Similar story, mouse nest in mine, chewed up 3 or 4 fan blades. Replaced heater core (leaking), installed new fan, heater works great. Just don't want to 'test it' at 40 below zero!
chewed 71'er is offline   Reply With Quote
Old 10-27-2002, 11:13 PM   #7
jasonrog
jasonrog's Avatar
I forgot to mention that I have a 205 degree thermostat. Boy does it make a difference!!
