Am I getting ripped off?
I just bought a lowering kit from performanceonline.com and I got 3" drop springs in front and 5" in back, hardware, front and rear sway bars, trac bar, and 4 drop shocks. I don't want to install this stuff under a car port so I took it to a couple shops around town. I also want my hooker headers installed but they require the zbar to be modified. This shop just did a '67 Chevy and had to do the zbar mod so they know how. They said that they would install everything, do an H-pipe and turndowns (i have two cherry bombs and just want to dump it behind the cab) and align it for $800. Should I be able to get all this work done for less?
Re: Am I getting ripped off?
Anyone on this forum live anywhere near Bakersfield CA and would be willing to do the install for less?
thats alot of work. unless you have the know how to do it yourself spend the money and get it done right.
That is what I was thinking but to me $800 is a lot of money. Anyone else? Is it worth $800?
Wherever you go, make sure to get a complete scope of services, including prices for the work to be performed. Better yet, you provide a detailed scope of work to the shop, so there is no misunderstanding of what needs to be done. Getting a quote that is apples-to-apples is very important. Also, I would check with shops that specialize in vintage vehicles. In closing, I don't think $800.00 is out of line for the amount of work that needs to be done. Good luck with the project and make sure to post pictures of the progress.
The guy has a 67 camaro big block in the garage (one of his personal old camaros) and he just did a slam on a '67 a week before I brought mine in. He did disc brakes on all four corners including drop spindles, ran the lines, installed the power booster assembly on the firewall, and he charged the guy $500 for the brake job. I don't know the complete bill but from what I know about him he does good work (been in business 19 years) and he specializes in suspension work (ie airbags and drops, lifts, leveling kits, etc.)
$800 doesn't sound to bad. If you don't have a c-notch then not to much involved in putting the coils up front and back. The headers may be more a pain depending on how much room you have. The problem with any vehicle is sometimes the things that should only take and hr to fix turn into 3 or 4. My luck is i start tearing something down and its old so i break something else and have to fix that too or forgot to account for someting else. If you have the tools, just do one thing at a time. I would put the coils up front first should take about hr or so, then another day do the back etc. When i first got mine i was working out in the dirt no cover, so a carport isn't so bad.
