Control Arms??
I've got a 5"/5" drop set up for my truck and read somewhere that with 3" spindles and 2" springs there might be rubbing between the wheel and the LCA.
I think it also mentioned that it only rubbed with 15" wheels, but cant remember. Will there be rubbing if I run my 15" wheels? What size of wheel will not rub? Also, the little crossmember right in front of the very rear X-member, and just behind the rear axle; can I cut that off without losing frame rigidity? Thanks
Wes 1980 GMC Sierra SCSB-2WD 1986 Chevrolet C10 SCSB-2WD Last edited by 1980GMC; 03-21-2008 at 06:26 AM. |
#2 | |
It followed me home?
Re: Control Arms??
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Spear and magic helmet!
Re: Control Arms??
I think he meant rubbing on the stock LCAs with the 3" spindle. I've heard a lot of people say that you need to do some trimming if planning to run 3" drop spindles with 15" wheels.
I've never tried it myself, but I read a lot. Hee hee. Rc415 and I believe bigblock73 both had problems with rubbing 15s and 3" drop spindles. |
#4 | |
Re: Control Arms??
6.0 powered square
Re: Control Arms??
yep on 3 inch spindles the caliper ears need to be grinded to clear 15 inch wheels
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Re: Control Arms??
Yes sir, I got 2.5 spindles and 2 drop springs with a coil cut out just to be crazy. I pushing as low as possible. Talk about rubbin and cut up inner fenders.
The lower control arms must be grinded down. Mine where a huge problem on the bottom side toward the back or cab. Only on big sharp turns. Easy fix though. |
Building Dreams out of Dimes!
Re: Control Arms??
I have drop spindles and I noticed that my wheel wieghts keep grinding off. This is the reason I thought about getting bigger wheels. I wonder if I would have problems with 20s...?
Re: Control Arms??
Maybe a 18" wheel set up wont rub?
Thanks for all the replies so far.
Wes 1980 GMC Sierra SCSB-2WD 1986 Chevrolet C10 SCSB-2WD |
