Old 04-04-2008, 03:40 AM   #1
tobins 52 gmc
tobins 52 gmc
S-10 front clip
I have a 52 GMC and a 1985 GMC S-10 . I measure the out side of the frame on the 52 and its 36in , the 1985 s-10 measured 36in on the inside ,with the same dept of frame 5 1/4 in .I was thinking of cutting the 52 frame back under the cab and matching the s-10 ,over lapimg it about a foot and using som plate under and on top, then i would not have to buy a kit or fab one up and to mention the time saved . This is my first build and i would like some input.Thanks robert
tobins 52 gmc is offline   Reply With Quote
Old 04-04-2008, 05:01 AM   #2
54 jimmy
54 jimmy's Avatar
Smile Re: S-10 front clip
buy the kit and save your self a lot of work. i did something simmilar to what you plan on doing. trust me buy the kit you won't be dissapointed.
54 jimmy is offline   Reply With Quote
Old 04-05-2008, 02:20 PM   #3
weldvair@embarqmail.
Re: S-10 front clip
Tie s10 IFS is too narrow period. You have to bolt on spacers, so why not start w/a IFS that track matches your trk
Don meyer-Mech Engr
weldvair@embarqmail. is offline   Reply With Quote
Old 04-05-2008, 04:45 PM   #4
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: S-10 front clip
can't you make that up with proper wheel backspacing?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 04-06-2008, 04:42 AM   #5
Re: S-10 front clip
No....you can not make 6" w/BS.
Don
Old 04-06-2008, 11:50 PM   #6
1-ton of fun
polishing a turd
Re: S-10 front clip
oh, i didn't know what kind of dimensions we were talking here
Old 04-07-2008, 01:53 AM   #7
The AD track is 6" wided than a s10, thus the wheels get lost under the nose w/out wheels spacers.....look at pics of them. The latter trks are even worse.
Adding puts more force on the bearings & ball joints.
It seems like the most common spacer is 2" thick.
Old 04-08-2008, 02:34 AM   #8
tobins 52 gmc
tobins 52 gmc
Re: S-10 front clip
hi guys , im going to buy a mustang 2 clip ,i can order it local . I was trying to find out if anybody used the s-10 clip and if so how did it work?The kit for the s-10 swap is a good idea but i have to order it threw the US and i am a little uneasy with that because i just finished getting screwed over by a snowmobile dealer up here ,to bad there is no dealer up here for that kit because there is a big market .
Old 04-08-2008, 03:40 AM   #9
Re: S-10 front clip
The Must II is a well accepted IFS for the AD trk......good luck & if you need installation advce just ask.
Don
