04-07-2008, 07:37 PM | #1 |
Window Glass Glue?
Just put new regulators in the doors and as I was lowering the passenger side, I noted that the window wasn't coming down. Got the door panel off and discovered that the glass had separted from the metal track at the bottom! I presume I'll need to "glue" that back in. Would I use silicone for that?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
04-07-2008, 08:05 PM | #2 |
18 Till I Die
Re: Window Glass Glue?
I think back in the day they used a rubber/sticky type paper. You can see it on your vent windows. Silicone should work, when they put mine in they used urathane like for installing windshilds.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
04-07-2008, 08:11 PM | #3 |
Its a urethane glue. Silicone usually doesn't work.but some cars have it on the tracks. I would go to a glass shop and see if they will sell you a tube We get the stuff but it comes in a black tube with no brand name. I will try and find out where we get it. Don't waste your time with stuff you think might work. Get the real stuff made for the tracks. 3M , norton and other companies sell it.
04-07-2008, 08:25 PM | #4 |
'71 chevy s.bed/s.side
From the factory they actually used glass setting tape. It is difficult to use. You can still buy it from some glass companies. but the urethane is good stuff. If it's applied properly it will stick.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
04-07-2008, 08:35 PM | #5 |
i used marine grade silicone to put my windows in.. i think it works pretty good
04-07-2008, 08:36 PM | #6 |
YOu can get the urethane at Auto Zone, Advance Auto, O'rielly's.It's the same stuff you use to glue in windshields. Any decent supply store should have it. It's usually on the bottom shelve where they carry the gasket silicone "BLUE GLUE" as I call it. I actually went to Advance Friday for some. Just be careful because that stuff will make a mess real quick and isn't forgiving on what it gets on.
It looks like a tube of caulk, in a white metal tube(ususaly) made by 3M. If I had the part # I'd give it to you. It was 14.99 a tube here. But good stuff once it has set.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
04-07-2008, 08:46 PM | #7 |
We install glass and we won't use the glue made for window sealing because its not the same glue for the window brackets. The stuff we use sets up in 1/2 hr and the car can be delivered. We have used the window sealer and then the customer brings the car back cause it pulled out. We lose money. We buy the real stuff now.
