Old 04-29-2008, 10:33 PM   #1
moneyeater
moneyeater's Avatar
Unhappy The ship sinks slowly!
My cab is sagging on the driversside and i allready put some shims between the cab and mounts! And i realize that itīs still sagging!
What can i do about that and what is the problem?
Is the structural integrity weak? Do i have to take the cab of the frame?
In the pic you can see that the bodylines donīt match ihad them close with the shims and now its almost as bad as before!
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
ī81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 04-29-2008, 11:00 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: The ship sinks slowly!
Replace the cab mounts/bushings. It is either that, or your floor or the cab perches are rotting away. You don't need to remove the cab to replace the bushings.
bigblock73 is offline   Reply With Quote
Old 04-29-2008, 11:36 PM   #3
spr85gmc
spr85gmc's Avatar
SO THENHOW DO U DO IT ?
spr85gmc is offline   Reply With Quote
Old 04-30-2008, 01:49 AM   #4
84 400
Sb 400 club
84 400's Avatar
cab bushings are done with a 4x4 or any solid block of wood and a floor jack. remove bolt ,jack slightly remove old bolt, remove bushing, jack enough to fit new bolt and bushing, re torque bolt. some times it helps to loosen al the cab mount bolts.
Okay i know you may not need to use new bolts but I always replace mine after seeing some of the bent and sheared ones
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 04-30-2008, 01:54 AM   #5
bigblock73
yeller
bigblock73's Avatar
Ian pretty much covered it, but if you need more info, here you go.
http://www.73-87.com/7387garage/exte...b_bushings.htm
Old 04-30-2008, 08:28 PM   #6
moneyeater
moneyeater's Avatar
Hmmm-- the cabmounts are new ones from energy suspension and the cab was sandblasted,inspected and then painted. Ok all that was 7 or 8 years ago but the truck has never been on the street or even outside the shop!!!
Come have a look!
Old 05-02-2008, 12:04 AM   #7
moneyeater
moneyeater's Avatar
Is it possible that the framebrackets that hold the cabmounts are weak or loose and sag with the weight of the cab?
Come have a look!
Old 05-02-2008, 12:24 AM   #8
slug
slug's Avatar
Just Crawl Under And Check It Out. You Should Be Able To Tell If The Frame Mount Is Bent Or Comeing Loose From The Frame
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 05-02-2008, 05:01 AM   #9
tyjoja
also change your front body bushing on either side of the radiator, did all six of mine and had no trouble at all, hear some have trouble getting the bolts loose if you have any probs with rust. I also bought the poly bushings from energy suspension. good luck
tyjoja is offline   Reply With Quote
