Old 05-08-2008, 01:44 AM   #1
vortec67c10
vortec67c10's Avatar
hood fitment problem!!
as you can see, every time i close the hood the rear stays up a slight bit. it allows me to push it back down but as soon as i open it again, it stays up. it seems a though the springs are to stiff but it used to not do this. what do you think?
5.3 Vortec
Redline stand alone
700R4
B&M on the floor
Lots of rumble
vortec67c10 is offline   Reply With Quote
Old 05-08-2008, 01:50 AM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: hood fitment problem!!
I thought the springs being tight would be a good thing as that would help pull the hood down tight...someone correct me if i'm wrong on that, or your hinges have moved.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 05-08-2008, 01:53 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Did you just replace any parts like the cowl to hood seal? Mine did that for a while until it got settled in.
First, be sure and lube it real good... Someone mentioned to spray WD-40 and work it up and down gently to break any old crud and corrosion loose... Then, as someone else mentioned in yet another post, loosen the rear bolts and lift it up so that the back end of the brackets go down and retighten. That's what I did on mine and it worked.
68gmsee is offline   Reply With Quote
Old 05-08-2008, 02:36 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
lube it real good, all the pivot points. Then if it is still doing this, do as 68gmsee described. but BE CAREFULL when you shut the hood. You may need to loosen the hood to hinge bolts and slide the hood forward.
If pivot points are lubed... this is a perfect indication of tired springs.
Old 05-08-2008, 03:32 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Lift your hood, then grab the front of it with both hands and move it from side to side while watching the hinges. If the rivettes on the hinges move around, then buy new hood hinges. I would be willing to bet yours are worn out.
You could also loosen the hinge bolts on the fenders, then push the hood upward so the back of the hinge pivettes downward, then tighten the bolts back up. If it sets down you are good to go, if not looks like hinge replacement.. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-08-2008, 04:21 AM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Wes is right... as usual
Tom Vogel is offline   Reply With Quote
Old 05-08-2008, 06:08 AM   #7
aventur1
aventur1's Avatar
Bolts on the fenders? Ok let's see pics. which ones? Pivet point?
aventur1 is offline   Reply With Quote
Old 05-08-2008, 10:46 AM   #8
67shortie
Green club
67shortie's Avatar
I would start here, look to see if the rear of the hinge at the rearmost bolt at the fender has adjustment left. If you see the adjustment slot showing at the top of the bolt, loosen it and push up on the hood to bring the rear of the hinge down like WES said. This will bring the back of the hood down towards the fender/cowl when closed. If not, something is out of whack with the hinges.
On a side note, everytime I adjust my hood I put a couple of towels over the fenders just so I don't get chips etc....
Hehe, look like I am repeating what everyone else said already
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 05-08-2008, 01:30 PM   #9
gmc67swb
gmc67swb's Avatar
Time to trash them hinges...Mine was doing the same thing,replaced them now all is good...the springs aren't there to hold the hood down there for helping to lift the hood when opened....good luck
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 05-09-2008, 12:58 AM   #10
Longhorn Man
gmc67swb... if you put new springs on a hood hinge that sticks up in the back, the hood will sit flat 9 times out of 10. The springs are streatched in the hood closed position. What do you think makes the hood pop up when you hit the latch?
Old 05-09-2008, 01:03 AM   #11
class01
class01's Avatar
What part of texas you from? Did you install that 5.3?
class01 is offline   Reply With Quote
Old 05-09-2008, 01:07 AM   #12
mike nutt
69fatmotor
mike nutt's Avatar
mine did the same thing and new springs did not help. once i replaced the hinges the hood fit great. the local dealer got me new GM hinges .
mike nutt is offline   Reply With Quote
Old 05-09-2008, 01:10 AM   #13
gmc67swb
gmc67swb's Avatar
Longhorn not to be rude - your right there stretched when closed that is to help lift the hood..if there is no adjustment left in the hinges to bring the ends down near the cowl then they are worn out no spring will fix it....time to replace them....
Old 10-30-2015, 07:24 PM   #14
elf w/capital T
Vortec, what did you end up doing with the hood springs?
elf w/capital T is offline   Reply With Quote
Old 10-31-2015, 12:06 AM   #15
LockDoc
The Older Generation
LockDoc's Avatar
Unfortunately he hasn't been on the board since 11/21/2013....
To get the back of the hood down with existing hinges---open hood----loosen the top front hinge bolts on the inner fenders, and the rear hinge bolts on the inner fenders. You may have to loosen the lower front bolts just enough so that the hinge will pivot on them but leave them snug. Now push the hood up till the hinges stop moving, ---now push it open a bit more to preload the hinges. (You will need two people to do this) Tighten all hinge bolts while the hood is being held up. Now CAREFULLY lower the hood--this may take a few adjustments to get it to sit just right (height wise). You may need to adjust the hood front to rear to allow for proper clearance with the cowl also.
LockDoc
Leon
Old 10-31-2015, 06:28 AM   #16
elf w/capital T
LockDoc , thank you for the information!
Old 10-31-2015, 08:18 AM   #17
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
X's 2!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-31-2015, 09:41 AM   #18
Fitz
Hinges are worn at the rivets. The elongated hole does this. Time to get them re-built.
Fitz is offline   Reply With Quote
Old 10-31-2015, 11:02 AM   #19
LockDoc
LockDoc's Avatar
If the hood has never been off that may be true. If it has been taken off and put back on that may not be true. The only way to tell for sure if the rivets are worn (and which ones) is to take the hinges off the truck and remove the springs....
LockDoc
Leon
Old 10-31-2015, 01:10 PM   #20
Fitz
LockDoc
I was giving the guys who assembled the truck after painting credit for enough experience and enough savvy to know how to re-install the hinges correctly. It's not hard.
Old 10-31-2015, 08:25 PM   #21
volksworld
rule number one...painters aren't mechanics.....
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 10-31-2015, 10:08 PM   #22
LockDoc
LockDoc's Avatar
I would bet that 85% of all ill fitting hoods are from people removing them and not reinstalling them correctly. Half don't even mark around the hinges before removing them....
At least not all of them..... I don't think that most of the painters even re-assemble them. They arrive as parts and leave as parts. Or the vehicle is painted without removing any parts....
LockDoc
Leon
Old 11-01-2015, 05:34 PM   #23
Fitz
Rule number 2:
If your painter doesn't remove fenders, hood and doors before beginning paint prep better find a painter who knows how to paint!
Old 11-01-2015, 06:19 PM   #24
elf w/capital T
Haha I wish I had known all that before I started my project!
Old 03-05-2016, 12:58 AM   #25
89AKurt
89AKurt's Avatar
Maybe a lesson is to not oil the hinges! LOL
After I did, it has popped up. Yes, the two close rivet pins are very loose, so does that mean a pair of new hinges?
1968 C-10 Long Bed Blue Cloud
1956 GMC 100 GYMEE
1969 Corvette that identifies as a Ferrari Daytona Spyder Fakerri
2016 Honda Civic EX-T Stealth
89AKurt is offline   Reply With Quote
