6 lug disk brakes?
Any one know of and 6 lugs I can use on my 63?
Re: 6 lug disk brakes?
check the truck shop, they have full kits with drop spindles and all.
![]() Join Date: Nov 2007
VonNicko,
I used CPP (Classic Performance Products) kits to put 6 lug disks front and rear on my 65. They sell the 87 model heavier front spindles (Western), bigger bearings, bigger ball joints and tie rod ends and the adapter sleeves to connect with the early model inner tire rod ends. The rear used an 80's cadillac caliper with emergency brakes. Good kits. Fairly reasonable prices. Worked well for me. http://www.classicperform.com/6092chevtrk.htm TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 Last edited by TR65; 05-16-2008 at 03:56 AM. |
Classic Heartbeat $569 complete.....bolts right up will need different brake lines and a proportional valve and Master Cylinder
http://www.classicheartbeat.com/cata...sion%20Kit.htm |
Thanks that helps alot.
now i have read somewhere that a particular year of chevy (van, i think) came from the factory with a six lug pattern and disk brakes. i believe it was right when they began switching from front drum to brake, but were still sticking with the six lug pattern....anyone able to confirm? the obvious benefit is being able to make the swap on the cheap without those spendy after market 6 lug conversions
![]() Join Date: Sep 2006
http://www.truckandcarshop.com/trucks60_72/t60_115.html Truck shop has them for $75 each..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#8 | |
| Bookmarks |
