70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Rear End Question
I am looking at buying a 1985 1/2 ton GMC Suburban and will be parting it out cause it was taken off the road as unroadworthy cause of the rust. My question is depending on what rear end it has and I'm assuming it will have a 10 bolt with 3:08's unless I get real lucky ( I should check my horoscope) and find a 3:42 posi, other than having to attach (weld) the trailing arm saddles to the rear end, will it go into my 72? I guess what I need to know is it the same length as the original in my 72.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Rear End Question
I am buying an 85 GMC Suburban and am going to part it out. I am assuming it has a 10 bolt rear end with 3:08 gears, unless I get lucky and it has a 3:42 posi. Other than having to weld the saddlles for the trailing arms on the Burb rear end, is it the same length as the original one in my 72 and will it just bolt in?
Son of a gun
Re: Rear End Question
same length. It'll bolt on after you weld on the mounting pads. Also will need a panhard bar mount on the pumpkin.
Bill BEATERS ARE NEATER |
Thanks for the info. I forgot about the panhard bar. Where would I get a panhard bar mount and how does it attach?
Retired Air Force Veteran
![]() Join Date: Aug 2007
The stud for the panhard bar is a part of the rear end (pumpkin housing). You may try calling ECE and see if the have a bracket for a stock set up or ECE also has a Super Track Bar for $109.00 and it goes from the D/S Frame to the P/S trailing arm. Good Luck, Harry
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
#6 | |
its all about the +6 inches
I am 99% sure it is. Take a tape measure and double check it that's the main reason you are buying it.
Thanks for the advice. I also put a message on the 67/72 board and was told it will bolt in but I will check the measurement first. I was also told I will need to do something with the panhard bar cause the Burb rear end doesn't have the stud for the panhard bar to attach. I really didn't want to go this route ( using a used rearend ) but with cost of gas going the way it is ,its either try to get a little better mileage or sell the truck and I RRREEEAAALLLYYY do not want to do that.
Greg, I have 6 inch drop coils and a Super Track Bar and what a nice setup. I changed my entire rear end out including leafs for trailing arms, 6 lugs to 5 lug and had to add various brackets to accomodate the changes. Lots of hard work but well worth it. Good Luck with your project.
#10 | |
luckily for me, mines NOT a daily driver. Weekend Fun till the tank gets low.
#12 | |
Merged....
Copied from the rules Quote:
#13 |
Sorry about that. I have never read the rules of the Board and have always used common sense when I'm on here. This particular rule makes no sense to me but I will abide by it. Sorry if I offended the powers to be !!!
#14 | |
The point of the rule is to keep all of the relevant information in one place. It is far easier figure out the results from a "search". It is also less confusing to people that are trying to help you with your question. The "flow" is interrupted and sometimes the information posted in multiple-post threads is conflicting, which adds to confusion.
