Old 05-17-2008, 03:14 AM   #1
clean71
clean71's Avatar
Ignition Hot Terminals???
I'm trying to finally get my Jimmy running again and I have some wiring questions. It seems like everything needs to be run to ignition hot. I've installed a 700r4 and msd ignition box, trans temp gauge, etc. What/How are you all hooking things like this to an ignition hot source? Hopefully that made sense. Any help is appreciated.
On a side note, if anybody in the Phoenix/Yuma/San Diego wants to help me get this thing running, I'd appreciate it. I'd pay gas, beer etc. I leave for Japan at the end of June and I need this thing running before it goes in storage.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 05-17-2008, 03:43 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Ignition Hot Terminals???
I ran a 4 circuit fuse box from the acc outs on the factory fuse box. Since there only 2 acc outs I jumpered the inputs on the new fuse box. Running my HEI, tach,gauges, and soon to be installed stereo off it. It's cool cause everything has a fuse.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-17-2008, 05:04 AM   #3
clean71
clean71's Avatar
Sounds cool. Where'd you get the 4 circuit box and how'd you wire it to the stock box? Thanks.
CPO U.S. Navy(Ret)
Old 05-17-2008, 06:14 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
I got it from Summit, it's the Summit brand 4 circuit fuse panel, about $12. I unplugged everything from the stock fuse boxes accessory outputs. There's only 2 connectors for the accessories on the stock panel. I took 2 pieces of short wire and put 2 ends into one connector and then 2 connectors on the ends. I did this twice. So you have 2 feeds coming out of the stock fuse panel going into 4 circuits of the new fuse panel. Mounted the new fuse panel right next to the factory one. The new fuse panel takes new ATO (?), style fuses.
Beat it to fit,
