#1 | |||
Union Electrician
Steering shafts
So do the steering shafts in the upper and lower control arms need to be replaced? Do they wear out? I have my uca and lca off the truck right now, but I have not been able to break loose the steering shafts, so if they do need to be replaced any suggestions on how you get them loose? TIA...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Re: Steering shafts
They often need replaceing. If there is any play in the shaft & bushing they need replaceing. If they are binding, grease them good & clamp the shaft in the vise & work the arm up & down. This may free it up. To replace them screw the caps off & remove the shaft. After putting on the new ones center the shaft in the arm.
#3 | |||
Union Electrician
Re: Steering shafts
They are not binding, and work just fine, I pulled them off my driver a couple of days ago. I haven't been able to break loose the screw caps off the ends. There is not any play in them that I can tell, but I thought I would replace them while I have them off.
Re: Steering shafts
Take a torch and heat them then try to brack it loose
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
Re: Steering shafts
Failure to keep em lubbed up they start squeeking that metal to metal contact and the upper/ lower ball joints. You would sound like spray bomb @ the board meet.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
