Old 06-01-2008, 05:53 AM   #1
Green Machine
Green Machine's Avatar
FREE - Eaton/Ho52 Rear End
Eaton/H052 Complete rear end from a 71 C20 2wd. 4.10 gears open rear end. Has good pinion seal, right rear wheel cylinder leaks and likely the axle seal also. Has 96,000 original miles, documented, its not 196,000 or more.
Center section should be good for sure, Brake drums could be good yet but don't know.
Also have a set of useable trailing arms from same truck, just starting to spread, better than many I've seen - also free.
I'll throw in the rear shocks too, nice and tight, we're doing new ones anyway
And the track bar too !!
Got some 16.5 wheels too, they might as well go too - Cleaning house here
Bring your truck !!!
We will have to cut the u-bolts off because we need the shock mounts.
It has been power washed and is not greasy and nasty.
Come and get it !!! Pickup only !!! Located in Estherville, Iowa
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-01-2008, 08:05 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: FREE - Eaton/Ho52 Rear End
i'm gonna put myself in line for this.
I need to talk to my brother tomorrow to see if this is what he's looking for. i'll take myself out if it's not.
IvelDesigns is offline   Reply With Quote
Old 06-01-2008, 05:25 PM   #3
Green Machine
Ivel - You are first in line
Old 06-01-2008, 11:54 PM   #4
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
What's up with those wheels you have? steelies? was this an 8 bolt rear end?
exmonkeypunk is offline   Reply With Quote
Old 06-02-2008, 02:56 AM   #5
Green Machine
Wheels are 16.5 x 6.5 - 8 bolt white steelies, original wheels, we have "upgraded" to more standard 16 x 6.5 - 8 bolt, easier to find more modern tires. Just taking up room, boys would like to reduce the tires to little rubber pieces and smoke after new motor goes in, else not worth much to us. We have 5 of them.
Also and update - Pulled rear end today, trailing arms really arn't too good, unless some one needs free ones bad, I'm going to scrap em.
Old 06-02-2008, 06:28 AM   #6
blkboot
is the rearend posi
blkboot is offline   Reply With Quote
Old 06-02-2008, 08:00 AM   #7
Green Machine
No, sorry. If it was a no spin/locker I'd be trying to sell it !!!
Old 06-03-2008, 11:43 PM   #8
Green Machine
ttt - still free
Old 06-04-2008, 01:50 AM   #9
IvelDesigns
sorry, i forgot about replying to this post until just now... we don't need it. hopefully someone else can put it to use. can't beat the price
Old 06-04-2008, 08:25 AM   #10
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Originally Posted by Green Machine View Post
ttt - still free
Would you consider taking less?
I am tempted because I have a NOS Detroit Locker that would go real well with this...
Heading toward Rochester anytime soon?
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 06-04-2008, 12:00 PM   #11
Green Machine
Actually, I think I am taking less than I could get scrap price for !!
Anyway, do you need the whole thing or just the center section ?
Reason I ask is that after getting it apart, the cups welded on the axle where the u-bolts go through are getting thin and would need attention.
I likely could deliver to Rochester for gas money.
Old 06-04-2008, 06:00 PM   #12
Merchant67c10
If you don't end up delivering this to chris h, I'd be interested in the axle and the trailing arms, if you still have these, I'd be more then happy to come take them off your hands
Bringing the ol' 67 back to life!
Merchant67c10 is offline   Reply With Quote
Old 06-04-2008, 08:20 PM   #13
Chris H
Chris H's Avatar
All I "need" is the center section...
If Merchant67c10 needs the whole thing, that seems like the thing to do to avoid time and trouble on your part GreenMachine.
If Merchant does not need the whole thing, then I will take the center section and work out a meet with you.
I appreciate the offer, and free parts are good parts!!! Very cool thing to do!!!
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 06-04-2008, 09:06 PM   #14
Green Machine
Merchant67c10 - When could you pick this up ? Prefer that, if not fairly soon, then on to Chris H.
Old 06-04-2008, 10:26 PM   #15
Merchant67c10
I'll let you know tomorrow for sure, whether i'll be able to get up there soon or not.
Old 06-05-2008, 06:48 PM   #16
Merchant67c10
Sorry but I looked at plans and everything, but I wont be able to make it up there anytime reasonably soon, sorry about that, thought I was gonna have time, but things change.
Old 06-06-2008, 10:15 PM   #17
Green Machine
Did you ever notice you can never get rid of free puppies? but, if you charge $10-20 they are gone within a week ??
Old 06-06-2008, 11:52 PM   #18
Green Machine
Chris H - you are next - I might be able to get Rochester in early July. How would $100 delivered for the center section be, or is that too much ? Let me know....
Old 06-07-2008, 09:21 AM   #19
Chris H
Chris H's Avatar
Consider the center section "SOLD".
PM coming with contact info... and THANK YOU!!
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
