Old 06-04-2008, 08:51 PM   #1
OJOE
Crew Cut
OJOE's Avatar
Blazer Tailgate Band on P/U Tailgate?
i know i have seen this here before. i want to relocate my tail gate handle to inside and install a brushed alum blazer tailgate band. any info or pics. thanks joe
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 06-04-2008, 09:46 PM   #2
1984 swb chevy
1984 swb chevy's Avatar
Re: Blazer Tailgate Band on P/U Tailgate?
You will need the inner mount froma truck tailgate band and the outer panel from a blazer to work on your truck. The outer panel is crimped around the edges. You can bend the edges back enough to remove the inner support(mounting bracket) and install the pick up mount. I hope this helps you.
1984 swb chevy is offline   Reply With Quote
Old 06-05-2008, 02:55 PM   #3
OJOE
Crew Cut
OJOE's Avatar
thanks, this is the info i need and i have 4 or 5 truck bands. joe
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
