rear axle bearings
i'm getting ready to do these, while i'm in there- is there anything else i can change/ replace with out special tools or restting the carrier? it is a 94 GMC 4X4.
thanks for any help/ suggestions. thanh |
![]() Join Date: May 2006
Re: rear axle bearings
You might want to check the Eastwood catalog if you're sure you want to tackle this job. You need a pretty stout dent puller with a special attachment on the end to remove the wheel bearings on the rear diff. A lightweight puller won't cut it. I did this job with my rear disk brake conversion a few years ago.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E (sold) 2018 Dodge Ram 2500 HD R/C |
![]() Join Date: Jan 2003
Check with your auto parts store, when I worked at Oreilly Auto, we sold a complete rear end rebuild kit. It had all four bearings, all three seals, crush washer, gear marking compound. They should also be able to rent you the correct puller.
2013 Ford F150 FX4 2006 Chevy Silverado 1500 1982 Chevy C1500 2020 Ford Explorer Limited 2008 Ford Escape |
Parts and more parts
This project, will not need to remove the carrier so you don't have to reset the rear end gears. I believe that we did everything from the outer ends, on my 91 DD, with ONE exception---removing the "C" clips. Do you have a posi rear end---do you want to consider one of the POWER TRAX units at this time. It installs without removing the carrier and gives you a good posi result in the end.
The axle tube bearings can be removed without removing the carrier, but the carrier bearings will require the carrier to be removed. Same for pinion bearings.
thanks for the replies. i will be renting the bearing puller.
thanh |
| Bookmarks |
