Old 07-06-2008, 04:24 PM   #1
MisterE72
Keep Your Nose Clean
???Drum Brake Assembly???
Greetings folks. I was wondering if someone can post a diagram the rear drum brake assembly for a 72 with a GM 12 bolt rear end. Thanks Mister E
OR if there is a link with step by step...hey even better
MisterE72 is offline   Reply With Quote
Old 07-06-2008, 06:24 PM   #2
john
member #16
john's Avatar
Re: ???Drum Brake Assembly???
Heres a pic if it will help.
john is offline   Reply With Quote
Old 07-06-2008, 06:50 PM   #3
MisterE72
Thanks. Do you have a different angle showing where the ebrake cable goes? Thanks again.
Old 07-06-2008, 06:51 PM   #4
va_tlc
va_tlc's Avatar
man that pic looks all to familar!!! i just re done my brakes this weekend, that e-brake cable is a pain, and if yr mech challenged as i am leave the other side alone until ya get the opposite side complete. i wore a path in the cement walking around lol, good luck and use jack stands for yr saftey
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 07-06-2008, 06:53 PM   #5
va_tlc
va_tlc's Avatar
see the shiny arm on the rear of his pic? right behinde the adjuster? thats where your e brake cable attaches not to the shiny arm but the arm right behinde it
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 07-06-2008, 06:58 PM   #6
MisterE72
Can the ebrake cable be installed "later on"? I'm considering ordering one of those stainless ones from Inline.
Old 07-06-2008, 08:17 PM   #7
va_tlc
va_tlc's Avatar
umm i dont think so, well i guess you would have to take your brakes back off when your ready to install yr new ones, but that will be a snap after you do this once it wont take long, are you gonna go ahead and replace your wheel cylinders while your at it, there only like 10 bucks each.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 07-23-2009, 01:08 PM   #8
ebfabman
The shoes are on backwards. The short lined shoe is the primary and goes to the front.
ebfabman is offline   Reply With Quote
Old 07-23-2009, 02:03 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
EDIT... I missed this... this one was brought back from the dead.
Me too....
Mr E, can you take a picture of the brackets you have there. I recently did this same install this past weekend (1st time I might add) but failed to get a shot from the bottom side of the brake system. If you can post a picture of the brackets I think we could walk you through it in a snap.
As far as adding the e-brake after the drums are together, I think you are our of luck, unless you have extra small hands.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-23-2009, 02:22 PM   #10
Rack Man
Here is the best drum brake assembly information on the planet...LOL
http://www.pbase.com/nufsed/drumbrake
You can click on pics to make them bigger!
I followed those instructions and I had not done a drum brake job in over 20 years....here's mine finished!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 04-11-2011, 03:29 PM   #11
belowme51
belowme51's Avatar
Thats the best link ever! thank you from all of those whom use it from this site!
belowme51 is offline   Reply With Quote
Old 08-28-2011, 07:11 PM   #12
goregalore
goregalore's Avatar
Special brake drum thank you
I am about to build the rear brakes on a 67 gmc c2500 3/4 ton. The rear brakes, nor emergency brake cables etc... do not exist on the truck so this thread has been very helpful. Thank you so much for posting the link to the "Brake Drum Assembly How to" it is for a 6 bolt hub but the setup is the same as the 8 bolt floating hub from what I can tell.
goregalore is offline   Reply With Quote
Old 08-28-2011, 08:34 PM   #13
hjewell2
hjewell2's Avatar
I was just getting ready to ask that ?. The short brake shoe faces the front on both the rear and front correct.
hjewell2 is offline   Reply With Quote
Old 08-28-2011, 11:04 PM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
heres one
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-31-2013, 08:33 PM   #15
RoughKuntry
RoughKuntry's Avatar
Can anyone get a photo of a 3/4 ton axle please. I can't seem to figure out why I mixed up the two brake struts and now I cant remember where they go besides at the top in between the brake shoes and under the wheel cylinders.
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
Old 04-30-2014, 12:09 AM   #16
BCOWANWHEELS
Yep short linned shoe to the front
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 04-30-2014, 08:14 AM   #17
goregalore
goregalore's Avatar
the truck is facing right in the photo. This is a picture of the right side of the truck. See the emergency brake cable?
I screwed it up first because I was working on the drivers side and didn't think about the fact this pic could have been of the passenger side.
Old 07-13-2014, 05:29 PM   #18
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Does anyone know if all truck 12-bolts use the same shoes and such?
For example; does 63-72 all interchange or does the 73+ 12-bolt also interchange with the earlier 12-bolts?
66 C20 Service Truck:
Old 07-14-2014, 04:13 AM   #19
RoughKuntry
Thank You guys. yall were alot of help
RoughKuntry
Old 10-01-2015, 10:09 AM   #20
LostMy65
LostMy65's Avatar
I found this thread that 10-bolt and 12-bolt interchange, but I still haven't found an answer to my question above.
http://Www.67-72chevytrucks.com/vboa...d.php?t=114315
Old 10-01-2015, 11:32 AM   #21
BCOWANWHEELS
I,am 99% sure all 12 bolt truck shoes are the same but I do know there are 2 different shoes and drums, 1 is h/d brakes other is std brakes.
Old 10-01-2015, 06:23 PM   #22
kcsa75
kcsa75's Avatar
Wow! A post that refuses to die. Been brought back from the dead five times.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 12-25-2015, 01:08 PM   #23
aotte1
Lostmy65, also researching 12 bolt drum brake options, thinking of changing my 65 rear brakes to the newer 12 bolt heavy duty "JB 5" brake package. Just starting to see if it will work. Looks like the backing plates are different from earlier ones, offset to the center of truck to account for the wider brakes shoes. As notes here before by Keith Seymore, this is one of GM's really good brake systems, used as a design goal for trucks.
Any information/can it be done, on retrofitting rear JB 5 brakes to the early 12 bolt 2" brake shoe axles?
Note: using '79 Dana 44 front axle, with the JB 5 brakes. I am planning to use the complete JB 5 brake system on '64 K10 build. Keeping all the original '64 parts so they could be retorfit later.
Les
aotte1 is offline   Reply With Quote
Old 05-21-2016, 10:55 PM   #24
DHighway
I have a 67 C-20 that im currently in the process of doing the rear shoes, pain in the butt, have not been done in id say 30 years, axles have to come off to remove hub and drum, pain in the butt, should have bought new wheel cylinders, went with rebuild kit, got one done, pain in the butt, lol, drums were surprisingly ok, but will replace oil seals and repack bearings did i mention its a pain in the butt.
DHighway is offline   Reply With Quote
Old 05-22-2016, 05:05 PM   #25
BCOWANWHEELS
I took my 70 front off late last fall put reassembly on hold for the winter then just as I was going to finish my tractor ran over my leg....... anyway time to finish em now and if it wasn't for this thread I don't know what I,d do................... thanks guys
