Old 07-15-2008, 12:28 AM   #1
azfab
azfab's Avatar
layen the 86 out
[IMG][IMG][/IMG][/IMG][IMG][IMG][/IMG][/IMG]here are some pics of the 86 still needs alot of work to get this thing to lay right[IMG][/IMG] [IMG][/IMG][IMG][/IMG] she still needs more about three mor inches to lay right.
lifes short fabricate as much as you can!
azfab is offline   Reply With Quote
Old 07-15-2008, 12:28 AM   #2
azfab
azfab's Avatar
Re: layen the 86 out
[IMG][/IMG]
Old 07-15-2008, 04:31 AM   #3
Slmd92DIME
Slmd92DIME's Avatar
Nice looking start.. truck looks to be in great shape... looks even better sitting on the floor.. Areyou going to do a Z or a crossmember drop?
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 07-15-2008, 06:27 AM   #4
jlaird
jlaird's Avatar
doesn't look like there's three more inches in that notch?? Lookin good so far though.
jlaird is offline   Reply With Quote
Old 07-15-2008, 10:22 AM   #5
azfab
azfab's Avatar
yeah i think a z is needed very badly. ill do it when i pull the motor its a little tired. and i still have to get drop spindels for the the front too. this truck is so clean! the body is so stright, i think is the strightest i have ever had lol.
Old 07-15-2008, 10:24 AM   #6
azfab
azfab's Avatar
im maxed out on the notch becase i dont want to cut the bed too muck shes got to be a work horse.[IMG][/IMG]
Old 07-15-2008, 10:29 AM   #7
azfab
azfab's Avatar
[IMG][/IMG]man these trucks are hard to lay, well not hard just a lot of $hit in the way. exhast, trany,crossmember. also the trans is like an inch frome the trans tunnel. so when i do the z i have to drop the motor instead of cutting the floor out. i think its easyer to fab new motor mount vs the floor what you think?
Old 07-15-2008, 10:31 AM   #8
azfab
azfab's Avatar
to day i will cut the bed floor and put it back on ill post some more!!
Old 07-15-2008, 11:15 AM   #9
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Hey nice project! Hey is that your 69 C10 in the avatar also, I might be wrong on the year, but got any pics of that one! Keep up the good work!
Sweet 85 C10 is offline   Reply With Quote
Old 07-15-2008, 11:25 AM   #10
joe231
joe231's Avatar
looking good!!!
Sweet 85 C10,
here ya go
azfab's '68 build
CHEVY ONLY
Old 07-15-2008, 01:39 PM   #11
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
azfab can you take some more pics of the 2 link set up you built and where are you puttin the bags?
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 07-15-2008, 09:41 PM   #12
87 dually burb
my short bus
87 dually burb's Avatar
looks good what is done to the front to get it that low
x2 on more pic's and details of 2 link rear
I'm thinking along the same lines as you for a 2link rear
run a 2x2 bar with a 2x3 (block) welded to top
in your pic is pinion current at height
thanks
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 07-15-2008, 10:32 PM   #13
GWEE
GWEE's Avatar
looking good
1985 GMC ( future plan pro tour build for the wife )
Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST
rules
GWEE is offline   Reply With Quote
Old 07-15-2008, 11:02 PM   #14
scotts62
One day...
scotts62's Avatar
Sweet man looks good!
Scott
93 crew cab build
Project 62
Old 07-15-2008, 11:30 PM   #15
azfab
azfab's Avatar
yeah the only bad thing is you have to set up your pinion angle @ ride highth. but its a simple system and i works well. when its layed out the pinion angle is about 9 10 degrees down hill. unies are alomost binding. if i ran longer ones it wouldnt be sutch a dreastic change with the pinion and wheel base movement. but its hard to do that on thes trucks with the frame dippen up and down. at first i had them under the frame till i noticed that i would need some drop block to aid to the drop, so i just moved them were the leaf hangers go. i built mine for 100 and some change. man i m definetly need to z her badly!!lol about 3'' to give her a nice rake. sucks for the rear but still look nice with some 20's. ill get some more pics for you guys on that 2link.
Old 07-15-2008, 11:58 PM   #16
azfab
azfab's Avatar
more pic[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG] sorry guys have to resiz them later
Old 07-16-2008, 10:17 PM   #17
Slmd92DIME
Slmd92DIME's Avatar
Looking really good.. keep the pictures coming
My Build Thread
Old 07-17-2008, 11:19 AM   #18
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
are you laying down a bead when you weld or just a succession of spot welds?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-17-2008, 01:39 PM   #19
azfab
azfab's Avatar
stiching
Old 07-17-2008, 01:40 PM   #20
azfab
azfab's Avatar
just got the tbi unit soon will be zing the fram ill keep you guys updated
Old 07-17-2008, 11:41 PM   #21
azfab
azfab's Avatar
ok help me out if i do a 3.5 or 4'' z it will lay hard but.. it will sit a little racked. whitch is ok the problem is i realy dont want to cut into the cab floor. i think if my musurments are correct ill have to drop the engine down and make a new tranny crossmember, witch is easy. i just dont want to go too over board with this truck lol. but still be a nice ride. what you guy think?
Old 07-18-2008, 01:36 AM   #22
joe231
joe231's Avatar
stiching
can i ask why???
CHEVY ONLY
Old 07-18-2008, 09:57 AM   #23
azfab
azfab's Avatar
Originally Posted by joe231 View Post
can i ask why???
why stich? its almost the same when you tig just dosent look as pretty as a tig. we do all our welds like this all over the plant. expecaly alumanum. ill have some better pics to post that show a little more
Old 07-18-2008, 10:26 AM   #24
azfab
azfab's Avatar
well all the pic i have are alum sorry[IMG][/IMG] but i love to wel alum!!!
