Old 08-23-2008, 06:44 PM   #1
67_C-30
I have a radical idea!
67_C-30's Avatar
What is needed to swap a SM465 in place of a 3 sp??
What is involved in putting a SM465 in a '67 K10 4X4 that has a 3OTT? I don't have the truck here to look at, and I don't know all the specifics except that it is a factory K10 with the original 327 and 3 sp. I don't know what transfer case it has, but it supposed to be stock.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-23-2008, 07:18 PM   #2
sandking
.....I am working on it.....
sandking's Avatar
Re: What is needed to swap a SM465 in place of a 3 sp??
You we be better off using a 465/205 that is already mated together. That way you have the bell housing, trans, xfer case and adapter that are meant for each other. Then you would need the clutch pedal and the neccesary shifters. The drive shaft length would need to be checked too.
View my build thread HERE
sandking is offline   Reply With Quote
Old 08-23-2008, 07:27 PM   #3
msgross
msgross's Avatar
yep. original tc was a rockwell T221, not highly sought after due to noise, availability of parts. Find someone selling the 465/205 setup and then find driveshafts to fit.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-23-2008, 10:03 PM   #4
67_C-30
67_C-30's Avatar
Would a '67 K10 with a 4 speed came with the T221?
My trucks
Old 08-23-2008, 10:20 PM   #5
msgross
msgross's Avatar
they all did... my 68 has 465/221 combo stock
205's came out in 69 i've been told.
The Garage:
Old 08-23-2008, 11:22 PM   #6
67_C-30
67_C-30's Avatar
So what would be needed to just replace the 3sp with a SM465? I don't think a transfer case change is anything the owner wants to do.
My trucks
Old 08-24-2008, 03:05 AM   #7
sandking
sandking's Avatar
I am sure the input shaft is different.
Old 08-24-2008, 06:57 AM   #8
My shortbed is a 3spd/NP205 and I`m making it a 4spd.Although I already have a nP205 I bought a complete changeover.The length of the input and spline count(maybe?)are different.The adaptor that mounts between is different.You can get this set-up for between $200-$300.It`s the best way to go.
Old 08-24-2008, 09:56 AM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
Now wait a minute, your saying you can just replace the 3 on the tree with an SM465 - when I did it I had to swap in a bbc along with it's SM465 to get rid of the 3 on the tree I had no idea I could just have replaced the tranny without replacing the motor.
Seriously though, when I was looking into this swap I heard from a few people that the bellhousing for the three on the tree tranny was different and I would need a different bellhousing. I did end up swapping engines so I never had to figure out if that issue was correct. Just something for you to keep in mind, a different bellhousing may be needed.
Gotta say I agree with the above advice to go ahead and update to an SM465/NP205 combo - in retrospect I wish I would have done that when I swapped in the SM465 in my 69 K20 - I'm presently replacing the Rockwell T221 for an NP205 as we speak.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-24-2008, 02:26 PM   #10
msgross
msgross's Avatar
I going for "nostalgia points" and keeping my T221...
actually i'm just to cheap to upgrade!
The Garage:
Old 08-24-2008, 08:52 PM   #11
I`ll see what the difference is between a 3spd bellhousing and a 4spd one.Does anyone know for a fact they are different.
Old 08-25-2008, 01:43 AM   #12
Blue_71
Bloo
Blue_71's Avatar
3 speed synchronized tranny has the same bellhousing as a SM465... my K20 has a 3 speed bellhousing on it (long story)
however, the pre 69ish unsynchronized 3 speeds (little short thing, i can try to get pics) has a different bellhousing. the bottem two bolts are wider, not in line with the top ones.
also, a SM420 uses a different bellhousing than a SM465... the input bearing retainer is smaller on a SM420
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 08-25-2008, 10:06 PM   #13
Yeah,I was thinking about this and I`m sure GM made all the differences in the adaptors.The driveshafts are the same and the t-case/crossmember are in the same place with all transmissions.
Old 08-25-2008, 10:23 PM   #14
Yukon Jack
Post Whore
Yukon Jack's Avatar
My 69 K20's Rockwell tc crossmember is not in the same location as my 70 K5's tc crossmember that was originally for a Dana 20 tc. I just went and measured and my 69 K20's crossmember sits 2 1/2" closer to the front cab body mount than my 70 K5's crossmember.
