Old 08-24-2008, 03:55 PM   #1
KiDD3
Brake Lines
I have a pondering question in regards to the brake lines on the '71 C-10...
Is there any reason the front brake lines couldn't be run along the firewall, instead of under the crossmember? My thinking of this is that it would be much easier to work on, plus they would be higher up in the truck out of the elements and possibly give a longer life. Of course they would need clamped down, but with so much room I don't see that being an issue.
Any opinions?
Pardon my questions...I'm a noob on a mission.
KiDD3 is offline   Reply With Quote
Old 08-24-2008, 05:40 PM   #2
umwtnt
umwtnt's Avatar
Re: Brake Lines
You can run your lines anyway you want to. But, dont run them higher than the master cylinder or you will have to install Residual valves, 10 psi for the drums and 2 psi for discs. I thing I spelled Residual correctly.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 08-24-2008, 06:42 PM   #3
cparman
sharp as a marble
Re: Brake Lines
I knew what you meant UMWTMT. If you ran them in the stock location, and spent the money for stainless, the lines would outlast your children
cparman is offline   Reply With Quote
Old 08-24-2008, 06:44 PM   #4
RaceAGMC
RaceAGMC's Avatar
Re: Brake Lines
Just for kicks, could you run braided lines from the master out to the wheels?
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 08-24-2008, 06:48 PM   #5
umwtnt
umwtnt's Avatar
Re: Brake Lines
cparman, I'm not sure what your referring to but there was no offense meant to anyone. I'm sorry if I did.
4 wheel discs
468 BB 700R4
Bagged
Old 08-24-2008, 08:29 PM   #6
biggreen292
Re: Brake Lines
i would suggest the stainless route too, being on the firewall would make them a pain to bleed out and the fluid would be hot from the engine which could cause boiling under hard braking. boiling=bad
http://i16.photobucket.com/albums/b3...fleet041-1.jpg
71 custom camper/20:292/saginaw, my first pickup
83 cutlass cruiser:307/th250c, lifelong project
96 caprice 9C1:LT1/4L60E, police package
83 buick regal estate: buick 350/m20
69 bel air:250/m21
biggreen292 is offline   Reply With Quote
Old 08-24-2008, 09:38 PM   #7
KiDD3
Re: Brake Lines
I guess seeing where the lines are at now, there doesn't seem to be much difference in regards to heat.
As for bleeding, wouldn't it be easier since the line would be up higher?
Old 08-24-2008, 09:41 PM   #8
KiDD3
Re: Brake Lines
Money is what I don't have extra of at the moment
