Old 09-04-2008, 12:01 PM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Antennas
What antenna should I install???....telescopic or non-telescopic???....
Let's see some pictures of other antenna options!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-04-2008, 12:33 PM   #2
nightmare
nightmare's Avatar
Re: Antennas
here's mine. stubby rubber antenna. works great.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 09-04-2008, 12:41 PM   #3
Andy4639
Old member
Andy4639's Avatar
Re: Antennas
Here is what I got.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-04-2008, 01:55 PM   #4
Mudder
Mudder's Avatar
Re: Antennas
I didn't like the idea of drilling into the cowl.
Mudder is offline   Reply With Quote
Old 09-04-2008, 04:23 PM   #5
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Antennas
Mudder, yours looks like a huge CB antenna...
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-04-2008, 04:27 PM   #6
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: Antennas
I like these types for a good Clean Look.
http://www.ecshylites.citymax.com/page/page/761353.htm
http://autoloc.carshopinc.com/produc...ts_id/9206/HAB
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 09-04-2008, 05:11 PM   #7
Mudder
Mudder's Avatar
Re: Antennas
With it being 29 inches tall you really don't even see it.
Old 09-04-2008, 05:18 PM   #8
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: Antennas
Mudders Defense.
496/T-56 in worx.
Old 09-04-2008, 06:11 PM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: Antennas
Here's some also http://67-72chevytrucks.com/vboard/s...antenna&page=2
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-04-2008, 06:23 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Antennas
I know this has come up before, but the solid mast antenna was not stock on our trucks. I know that there will be those who argue the opposite. The purpose of the fixed-length (solid mast) was for the FM wavelength. AM radios got better reception with longer a antenna length. But, the FM broadcast signal was not improved upon by a longer antenna.
SO, if you want a correct-appearing, i.e. stock, look, then a sectional antenna is correct. If you want an antenna that is more funtional for your FM radio (you don't still listen to AM do you?), get a solid mast.
Member Nr. 2770
Old 09-05-2008, 07:56 AM   #11
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Antennas
Thanks for all of your input!!!....Very good info here!
Geoff with a G
