Old 09-04-2008, 08:56 PM   #1
dhughins
dhughins's Avatar
86 steering box?
will an 86 power steering box work on my 64. i was told on here that the steering column wouldn't so will the box easily hook up to another column?
dhughins is offline   Reply With Quote
Old 09-04-2008, 11:35 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: 86 steering box?
You need this kit. http://www.classicparts.com/1960-66-...ctinfo/76-979/ It makes it alot easier to install the box. You do have to shorten the steering column. I put in a tilt from a van and now have a split shaft. The lower shaft is from a 70's truck. Just cut the factory end off and used a DD adn 36 spline u joint.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-05-2008, 12:55 PM   #3
19GMC63
19GMC63's Avatar
if your gonna use the 86 box, why not just go ahead and use the 86 column?
Then you won't have to worry about cutting shafts and using u-joints. Just collapse the 86 column by drilling out the two plastic retainers and move to the desired length. The hardest part about the newer column is modifying the column/bracket under the dash. All it takes is knocking off the 3 or 4 weld-nuts and moving them to match the holes on your factory bracket.
check this site out:
http://persh.org/Pickup/steering.htm
19GMC63 is offline   Reply With Quote
Old 09-05-2008, 04:53 PM   #4
dhughins
dhughins's Avatar
Even if the shifter is on the floor it would have to be a stick shift but the ignition is on the column as well, which you don't want.
this was a quote from someone on here. do they know what they are talking about?
is $150 a good deal on a '86 power steering box and tilt column?
Old 09-05-2008, 05:42 PM   #5
mbgmike
You should not have any problem with the steering box. They are a 605 box and fit from a variety of years. These pics are not a pretty way but it is an easy way. Every thing is a bolt up on the shaft. Use a collapsible intermediate shaft. Use the rag joint off the 86.
mbgmike is offline   Reply With Quote
Old 09-05-2008, 06:25 PM   #6
Chevy Fleetside
Acually the steering box in my picture is from an 86 sub.. And I am using a van column without the key in the ignition. I was going to try and use an 88 column but it was hard to get the high beam switch rod to clear the bracket so I back to basics.
Old 09-05-2008, 10:09 PM   #7
19GMC63
19GMC63's Avatar
I can't quite understand what they're trying to say... but the column ignition shouldn't be that big of a deal. If you want to use the stock ignition, then just remove the ignition switch/rod, and if your worried about the column ignition itself, then just dremel off the plastic and fill where it was. (I just left mine... wasn't a big deal to me... I just took off the rod and switch)
Old 09-05-2008, 11:33 PM   #8
Chevy Fleetside
The Van column dose not have the key in the column. I think they started that in 1981. No need for dremeling anything off or filling anything. That is what the difference is. No biggie.
