Old 09-20-2008, 08:09 PM   #1
TylerHuff
TylerHuff's Avatar
bags on control arms. coil spring rear
anyone that is still using the control arms on a coilsprung truck for a bag setup please post up im going to be bagging the rear of my truck soon and my wallet wants me to use the original arms instead of the 4 link that i wanted to do
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 09-20-2008, 11:03 PM   #2
Shane
Shane's Avatar
Re: bags on control arms. coil spring rear
lots, if not most here, use the stock trailing arm setups under their trucks ... just bolt the bag in place of the rear coil ... drill a few holes ... waa-laa, you're done
Shane is offline   Reply With Quote
Old 09-21-2008, 10:29 AM   #3
TylerHuff
TylerHuff's Avatar
the problem with just bolting the bag in place is that it wont lay out. so i was wondering if people are raising the whole frame section or just putting the bags over the axle notch and 2 inch block
1987 Gmc sierra
1962 Apache 10
Old 09-21-2008, 10:43 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
2" block still won't lay out. You will need a step notch, but before you can use all of it, the arms will hit the frame. I have seen people Z the rear just behind the cab.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-21-2008, 06:23 PM   #5
Shane
Shane's Avatar
you're right ... it won't "lay out" with bags on stock arms ... you also didn't say that's what you were attempting to do in your first post.
Old 09-21-2008, 07:37 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
You can get pretty low with stock rear arms, blocks and some mods to the wheel wells. If your on a budget, that's about as good as it gets. "Laying out" will add to the cost...$$$$
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-21-2008, 11:09 PM   #7
Ronin8451
Ronin8451's Avatar
The '64 I just bought will lay rocker with stock arms and a rear "Z" , but it hits the arms with the frame as it does. The cab is channeled 3" too though.
1970 SS El Camino Resto-rod
1951 Chevy 3100 ( in pieces at the moment)
1964 C-10 Long Step ( new daily play truck)
1999 SS Camaro & 1994 BMW 740IL Daily drivers
1969 SS Chevelle ( next in the resto line)
Ronin8451 is offline   Reply With Quote
Old 09-22-2008, 12:44 AM   #8
Frizzle Fry
Frizzle Fry's Avatar
bags on TA's in the coil location and 3" blocks. It might lay with smaller wheels/tires (those are 31.5" 22/40series), but then you wouldn't want to run such big blocks...
Frizzle Fry is offline   Reply With Quote
Old 09-22-2008, 09:07 AM   #9
Ronin8451
Ronin8451's Avatar
Here is the truck I just bought with 215/75/15's up front and 28/12.5/15 Sportsman Pro's out back. There is about a 1/2" between the floor and any part of the truck's frame/body completely aired out. The rear "Z" wasn't done very straight, so it will probably get re-done in 2"x3" tubing and plated to the frame correctly.
Rick
Old 09-22-2008, 09:47 AM   #10
jkaylor68gmc
jkaylor68gmc's Avatar
nice trucks, I always love the red Stocked out six truck.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
