10-18-2008, 02:14 PM | #1 |
Power Brake Mstr Cyl / Booster Angle - Too Much?
I just finished getting the new power brake master cylinder booster installed. I looked at a couple of other swap threads on the board, and mine looks like it's angled pretty far down to the front. Is that the correct orientation? It's also a bit off side to side as if it was twisted. That could be due to the pedal hanger being a bit messed up. Any ideas on whether to continue or do I need to look for something wrong?
Thanks. |
10-18-2008, 02:26 PM | #2 |
Re: Power Brake Mstr Cyl / Booster Angle - Too Much?
You have the bracket upside down
10-18-2008, 02:27 PM | #3 |
On my 69 it's tilted also. I asked about this before and it's normal.
10-18-2008, 02:37 PM | #4 |
Just hang'n around
Mine is out of a '71 and it isn't that tilted. I'd post a picture but don't have time right now.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
10-18-2008, 02:39 PM | #5 |
looking at the ones we have here in stock, you have it correct. I was wrong. but it sure looks down alot. the bracket is 1/4" per 4" slope approx,which is pretty hefty
10-18-2008, 02:41 PM | #6 |
Just hang'n around
Why are they tilted so much? That's pretty odd. Leaves a guy to think he could get more fluid in it if it was level.
10-18-2008, 03:20 PM | #7 |
I don't have a clue I would just be guessing. I just checked our 72 delivery van and it is tilted down to the front also and it just bolts to the firewall without a bracket. I am sure someone knows why.
10-18-2008, 07:29 PM | #8 | |
Active Member
It may be that if the booster were straight, it could hit the hood when you lowered it??? And they figured that there would be enough fluid to stop the trucks even with the m.c. tilted (providing there's "no" air in the lines). It's worked well for many years. Last edited by 68gmsee; 10-19-2008 at 09:42 AM. Reason: ooops... forgot the "no" |
10-19-2008, 12:14 AM | #9 |
thanks everyone. so long as that's how it should be I'll go on. it looked so far off that I figured I had done something like flip the bracket.
10-19-2008, 05:18 AM | #10 | |
I am a Referee of life.
Another hypothesis; The booster may be angled so that it is level when the truck is loaded.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-19-2008, 09:43 AM | #11 |
Active Member
10-20-2008, 12:26 AM | #12 |
Just hang'n around
I guess if a guy just got tire of looking at it that way, he could fag a tapered shim to sit behind the bracket. But, that would also mean modding the push rod just a bit.
10-20-2008, 12:42 AM | #13 |
Bothers me too but it's bone stock....I looked at my bracket thinking it might flip but the pattern looks like it might not line up the other way. Anyone tried that yet?
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
10-20-2008, 09:04 AM | #14 | |
Active Member
But, GM engineers just plain "over engineered" this contraption. Too many links, rods, swivels and angles. |
