Old 11-06-2008, 02:39 PM   #1
yellowGT
yellowGT's Avatar
I need help with my doors
can manual doors be used instead of electrical doors. Had to replace the doors and now stuck with the manuals. If they will work I know I would have to cut out a section of the door to fit in the window motor.... right? or Im I wrong and cant use these doors at all? Help!
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 11-06-2008, 03:08 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: I need help with my doors
As long as the doors are 77+, then you can use manual doors and retro-fit your PW/PL stuff into them. As noted, you will have to cut a hole for the wiring.
bigblock73 is offline   Reply With Quote
Old 11-06-2008, 03:16 PM   #3
yellowGT
yellowGT's Avatar
I dont know what year they came off of but I know i have to make the holes for the wires and the hole on the sides to fit the motor assembly but Is there anything else besides that? I did feel the window bracket inside so I might be able to use them
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 11-06-2008, 03:39 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Are you sure about the hole for fitting the motor in. I think that most doors are the same, with the exception of the wiring hole.
piecesparts is offline   Reply With Quote
Old 11-06-2008, 04:10 PM   #5
bigblock73
yeller
bigblock73's Avatar
Yes, all 77-87 doors are the same regardless if they came with power options or not. The earlier 73-76 doors did not come with power options bacause they would simply not fit...hence the redesign in 77.
Old 11-06-2008, 04:57 PM   #6
yellowGT
yellowGT's Avatar
ill get home and take a pic of them so you can see what im talking about. So far thank you all.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 11-07-2008, 05:10 PM   #7
yellowGT
yellowGT's Avatar
I got the problem resolved..... thank you guys
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
