11-06-2008, 05:57 PM | #1 |
Brake Dust Shields
Anyone know of a place where I can get new brake dust shields for the front of my 87 1/2 ton 4wd? Only ones I found are way more then I wanna spend.
Thanks Nick '87 1/2ton 4wd-mild 355, TH400, long tubes, 3" single Magnaflow, manual locking hubs '88 SS-built 357, 2004r, 9.5" 3200 stall, 4.10 posi 8.5 '94 9C1-174k, built 4L60e, Hughes 2500 stall, 3.73 posi, 93oct tune, 2.5" true duals |
11-06-2008, 06:25 PM | #2 |
On a budget like Fred Sanford
Re: Brake Dust Shields
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
11-07-2008, 06:51 AM | #3 |
I guess I shoulda said front brake backing plates. These are the suckers that bolt to the spindle and in a sense cover the inner side of the rotor.
11-07-2008, 07:59 AM | #4 |
Are you talking about the caliper mounting brackets?
11-07-2008, 08:55 AM | #5 |
Those are them actually. Guess I had the name wrong.
11-07-2008, 10:29 AM | #6 |
Happy to be here
No, you had it right, they are dust shields. I don't think you want to mount your caliper to them.
What souce have you tried that was so pricey?
11-07-2008, 11:28 AM | #7 |
STILL PLAYS WITH TRUX
I'd get them from the junk yard if ya got a U PULL IT or something like that go there you will probably get both for les than 20 bux!
11-07-2008, 12:55 PM | #8 | |
I know those may serve double duty as an inside dust shield but they are definitely very thick (1/8?) and are held on by 6 studs to the knuckle and the cut out and two bolt holes there are for the caliper. Last edited by blink32; 11-07-2008 at 12:56 PM. |
11-07-2008, 05:57 PM | #9 |
Exactly what I'm looking for. The actual dust shield part is all rotted, but caliper mount is fine.
11-07-2008, 06:18 PM | #10 |
Crazy
I agree with you blink, the calipers do mount to them, I would even offer a picture, but I happened to stick my tires back on last night. They are in fact pretty thick, I had my truck sitting down on the ground on them for a couple weeks until I stuck the tires on. Made it lasier to lower to lift the cab back on. Good luck finding them 454, I would also suggest a junk yard/u pull it of some sort. LMC only carries the 2wd ones from what I see.
77 SB Stepside in a bunch of pieces scattered around the garage. Last edited by tgh117; 11-07-2008 at 06:19 PM. |
11-07-2008, 07:23 PM | #11 |
Happy to be here
You are correct. I failed to see the 4WD part of his post. My bad...
