1970 C10
Disc Brake ?
i got a 72 frame with factory discs for my 70 C10, can i use/not use power booster, master cylinder and proportioning valve?
I really don't want to spend the little money i have on this. Thanks! |
Re: Disc Brake ?
you can not use the 70master and combination valve with the disc brakes
I am a Referee of life.
Re: Disc Brake ?
cdowns is right.Use the MC from the front brake system you put on the truck.You can leave out the Booster but may need to check brake (pedal to MC rod length.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
1970 C10
Re: Disc Brake ?
The booster is alright to use though?
Thanks! |
Re: Disc Brake ?
You can use the booster. Get a disc/drum MC for a 72 and you should good. If any adjustment is needed, it would be the stud coming out of the booster pushing on the MC. There should be just the slightest of gap between the two at rest.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: Disc Brake ?
You will still need a proportioning valve for the disc brakes. The 70 does not have a proportioning valve with drum brakes as cdowns mentioned.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
