Old 11-17-2008, 04:15 AM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Do I Need This Part?
I'm Cleaning up my wireing and this is bulky Do I need it or can I get rid of it
I checked LMCtruck Catalog and it is labled as a Voltage Regulator It has to do with the Alternator I think, I have a 1 wire Alternater in my truck So Can I chuck it or is there something I need to do before I can chuck it Or should I just buy a New one since it looks old....If I need to keep it Does anyone know where I can buy the correct (RUBER MOUNTS) Ruber spacers and screws to mount it back Thanks..........
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 11-17-2008, 04:39 AM   #2
FLEET72
FLEET72's Avatar
Re: Do I Need This Part?
Yes that is an external Voltage Regulator. Since you have a 1-wire alternator then you no longer need it.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 11-17-2008, 07:59 AM   #3
big_al_71
big_al_71's Avatar
If you have a one wire alternator then Toss it!!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-17-2008, 08:01 AM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
You should have a jumper wire for your harness to take it's place.
I wouldn't throw anything away until your project is done! Just put all the not needed items in a box and let it sit until your done.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-15-2008, 07:03 PM   #5
Hawker7
I ran across this thread while looking on how to convert to a one wire alternator. I'm not having any luck with the search so can anyone tell me the best (and cheapest) way to go to a one wire?
Hawker7 is offline   Reply With Quote
Old 12-15-2008, 07:06 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Chuck it!
leddzepp is offline   Reply With Quote
Old 12-15-2008, 07:08 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
www.wiringharness.com has harnesses that they sell for those who have 1-wire alternators. If you are doing some serious upgrades and/or replacing wiring, then you may want to consider their products.
Member Nr. 2770
Old 12-15-2008, 07:22 PM   #8
Hawker7
what do I need to buy? Just a one wire alternator and the wire adapter?
Old 12-15-2008, 08:31 PM   #9
cdowns
cdowns's Avatar
save it for the guy that wants a stock AC/DELCO part for his 100point resto
Old 12-15-2008, 08:41 PM   #10
65chevy4x4
Building a old truck, is like building model cars when you were a kid.There is parts left over,---
65chevy4x4 is offline   Reply With Quote
Old 12-15-2008, 11:06 PM   #11
Bruce88
Bruce88's Avatar
Hawker7 The cheapest and simplest way to convert to a single wire internal regulator alternator and maintaining the stock wiring harness is to use converter kit. But first you have to identify the alternator type that you will be using (see attached picture).
Normally if you are going to buy an alternator to replace the stock one with a single wire it would be an SI
For CS Alternators use part #37787 converter kit by M&H Electric Fabricators
For SI Alternators use part #27555 converter kit by M&H Electric Fabricators
Converter kits can be found at ( http://www.wiringharness.com/ ) use the search function or contact Wess at Classic Heartbeat Pickup Parts ( http://www.classicheartbeat.com/default.htm ) site supporter.
Hope this helps
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
