Old 12-04-2008, 12:08 AM   #1
Brad2thabone
Brad2thabone's Avatar
Smile My watts link setup...what do you think?
This my 67 longbed setup. The pictures are when its layed out, the bars are parallel at ride height though. any feedback? besides the crappy tack welds lol.
[IMG][/IMG]
[IMG][/IMG]
and a little picture of what it used to look like
[IMG][/IMG]
Brad2thabone is offline   Reply With Quote
Old 12-04-2008, 12:16 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: My watts link setup...what do you think?
Sweet
Did you build it or buy a kit ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-04-2008, 12:20 AM   #3
scotts62
One day...
scotts62's Avatar
Sweet! X2
Scott
93 crew cab build
Project 62
Old 12-04-2008, 12:31 AM   #4
Brad2thabone
Thanks guys, ive been checkin out both your projects, and both of them are sick. Spray-bomb, hows that cadillac monster comin?
I got it from my friend Rich, He has a fabrication shop just a couple miles away.
Old 12-04-2008, 12:45 AM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Oh the drag truck is just sitting waiting its turn
I dont have the money, time, or space to work on it right now
Sinister
Killer
Old 12-04-2008, 02:00 AM   #6
72hotrodder
THE TOY STORE
72hotrodder's Avatar
will the bushings not allow wobbling?
72hotrodder is offline   Reply With Quote
Old 12-04-2008, 05:03 AM   #7
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
those bushings are stronger and firmer than what you'll find in a stock leaf spring so I think it'll do just fine.
Sounds like you got the important part about the bars parallel to each other and the ground at ride height.
Some will tell you that it is better to have the center pivot mounted to the frame and the bars to the axle and it is but I have done several similar to your set-up and they all worked out ok. My old shop truck was a 1ton dually that I ran a watts on and used it to tow like nobody's business and it's still in service.
Looking good,
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 12-04-2008, 12:49 PM   #8
Kontrol Phreaks
Kontrol Phreaks's Avatar
Looks good.
I used poly bushing and heim joints on mine and never had any problems.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 12-04-2008, 03:20 PM   #9
HOOPTY67
clint- did you ever finish your C10? can't wait to see it.
-mike
-mike
HOOPTY67 is offline   Reply With Quote
Old 12-04-2008, 03:33 PM   #10
Kontrol Phreaks
Went to a new home in the bay area to a guy who "had to have it". I've since moved on to another early model C10 that will be surfacing in 09 if all goes well.
later
- Clint -
Old 12-04-2008, 05:39 PM   #11
Slmd92DIME
Slmd92DIME's Avatar
Looks good man.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 12-04-2008, 07:01 PM   #12
jlaird
jlaird's Avatar
I think it looks good. Why the bushings at the axle though?
jlaird is offline   Reply With Quote
Old 12-04-2008, 11:00 PM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
What's the depth of the KP piece- i.e; how far past the diff cover does it protrude?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-04-2008, 11:03 PM   #14
Twisted Minis
Twisted Minis's Avatar
Easy way to mount it.
It looks good. A little far from the axle for my taste visually, but it should work great.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 12-05-2008, 12:17 PM   #15
Kontrol Phreaks
It's was designed to be snug as you can get it to the diff cover, and sticks out past it appx 2.0 - 2.5 inches.
- Clint -
Old 12-05-2008, 12:40 PM   #16
hotrodhomi
hotrodhomi's Avatar
fyi, on my 2wd blazer i had to mod the crossmember between the rear and the gas tank. i have the kp watts.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 12-05-2008, 12:42 PM   #17
Kontrol Phreaks
Blazers have a different crossmember location behind the axle than the trucks, and we designed it to work on the truck chassis. We didn't have a blazer to test it on, and I appericate your helpful information. I will not that when working with early model blazer owners.
Thanks again for the info.
Clint
- Clint -
Old 12-05-2008, 02:29 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
homi- did you ever get any pics of your final configuration? Curious to see how it worked out for you.
Side note- how do these perform on an uneven surface, i.e; entering a driveway at an angle? That was the only time my old panhard setup would rub.
-Chris
Old 12-05-2008, 09:12 PM   #19
Brad2thabone
Thx for the comments guys. Its my first truck and its cool to hear from some of the pros
yeah it is a little far from the diff cover, but if i ever need to take it off it will be easy to get too haha
Old 12-05-2008, 10:14 PM   #20
hotrodhomi
hotrodhomi's Avatar
No pictures, but it looks just like the KP that was posted. Where would the panhard rub? I've had no problems with mine except for the unforeseen crossmember issue. Its never rubbed on anything and I've scraped just about everything else at one time or another when I'm too low for the conditions.
'66 impala ht
Old 12-05-2008, 11:33 PM   #21
gringoloco
A guy with a truck
gringoloco's Avatar
With the 20x10s out back, when entering a driveway at an angle, the tires would rub on the inside of the tubs just slightly. I was just wondering if it would get in any kind of bind when the axle is articulating like that, or keep the axle relatively straight.
-Chris
Old 12-06-2008, 04:59 PM   #22
hotrodhomi
hotrodhomi's Avatar
I get zero side to side movement between all the way aired up and no air at all. I don't think it moves at all.
'66 impala ht
