Old 12-04-2008, 05:08 PM   #1
lks dcvn
lks dcvn's Avatar
Corvette Ram Horn Purchase Question - yes another one
For the corvette ram horns (2.5" outlet) - do I just need to buy the same part number (674503) for both sides and then use a cut off wheel and a grinder to shave down the extra brackets on them...
Anybody have a before after picture of them for the mods they made to clean them up for install?
lks dcvn is offline   Reply With Quote
Old 12-04-2008, 07:19 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Corvette Ram Horn Purchase Question - yes another one
Good question. The ram's horns that I remember had the extension in the casting on the driver's side to mount accessories. But, that was before the heads were drilled/tapped. I have several sets in the garage, but not the larger diameter outlets that the 300-horse 327 engines had.
Member Nr. 2770
Old 12-05-2008, 07:31 AM   #3
Blazer1970
Blazer1970's Avatar
Yes, same part number on both sides. Saw/grind off the extra bosses if they are in the way or you want a better look.
Blazer1970 is offline   Reply With Quote
Old 12-05-2008, 07:47 AM   #4
jaros44sr
jaros44sr's Avatar
Not sure if a cutoff wheel will be deep enough, maybe in chunks, but I used a bandsaw. Mine are to ugly to post up pics
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-05-2008, 04:54 PM   #5
Blazer1970
Blazer1970's Avatar
I clamped mine in a big horizontal band saw and cut them off close, then used a buffer/grinder to smooth them out. They came out nice, but the Blazer is in storage, so no pictures till spring.
Old 12-08-2008, 03:51 PM   #6
lks dcvn
lks dcvn's Avatar
bump for pix - from anybody to show the portion that was cut off...
Thx.
