Old 12-05-2008, 07:13 PM   #1
Purs
Got Big Block?
Purs's Avatar
flat towing
Can my '72 4x4 Blazer w/automatic transmission and stock transfer case be flat towed? If so, do I need to unhook both the front and rear driveshafts or neither?
thank you.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 12-05-2008, 07:45 PM   #2
msgross
msgross's Avatar
Re: flat towing
If you unlock the front hubs and place the transfer case in neutral then the only thing turning should be the rear axles and driveshaft...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-05-2008, 07:57 PM   #3
Dooley
Dooley's Avatar
Re: flat towing
GM says,
1.Transfer case in 2 High
2. transmission in neutral
3. maximum speed 35mph
4. Maximum distance 50 miles
Note: For speeds or distances greater than above, both propshafts must be disconnected at the axle carrier and secured in a safe position. It is recommended that they be removed and stored in vehicle.
Note: Do not exceed speeds as per State laws for towing.
Dooley is offline   Reply With Quote
Old 12-05-2008, 10:38 PM   #4
sweet70beast
sweet70beast's Avatar
Re: flat towing
I personally hate to pull automatics in neutral, seen too many of them burned up. Since it is a 4x4 put the transfer case in neutral and you don't have to worry about the trans.
The automatic trans has no fluid flow if the engine isn't spinning regardless of what the rearend is doing and that's how they get toasted and why GM puts limits on distance and speed. With the T-case in neutral only the output and driveshaft/axle spins. The spinning of the output gears causes the oil the splash and lubricate everything inside the t-case so you could pull it to the moon and back and not have a problem. If you do it this way you don't even need to take the transmission out of park.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 12-06-2008, 10:18 AM   #5
Re: flat towing
^That`s how I`ve always towed.No problems.I`m not sure how GM came up with their recommendations.
Old 12-06-2008, 11:36 AM   #6
pumpkin
pumpkin's Avatar
Re: flat towing
I've towed my 72 about 20,000 miles so far, and no problems. I put the trans in park, t/case in neutral and away we go.
pumpkin is offline   Reply With Quote
