Old 12-15-2008, 05:49 PM   #1
juicer25
Heater problem
It's getting really cold in Deer Park! It should reach -20 before Friday and I like driving my blazer around so I need to get the heater fixed. It worked fine two years ago, but it sat for about 2 1/2 years until I put a new motor in it. I hear the fan blowing but don't feel any air coming out. Any suggestions?
juicer25 is offline   Reply With Quote
Old 12-15-2008, 06:44 PM   #2
Bentblazer
Bentblazer's Avatar
Re: Heater problem
Some mice may have found a new home, thats what I found when air didn't move
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 12-15-2008, 07:18 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Heater problem
Pretty common to have mice nesting.
Also, I've had problems with the squirrel cage getting stuck so the fan sounds like it's running, but no air is coming out.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-15-2008, 11:34 PM   #4
juicer25
Re: Heater problem
Thanks for the help! I will take it apart and see what I can find out!
Old 12-18-2008, 11:34 AM   #5
juicer25
Re: Heater problem
Darn mice! They made quite the nest in there! It wasn't that bad getting it taken apart, cleaned out and put back together. Now everything works great!
Old 12-18-2008, 12:08 PM   #6
jaros44sr
jaros44sr's Avatar
Re: Heater problem
Glad ya got heat, nice to see ya drive it in the winter. You can do a bolt in upgrade to a newer year blower motor... I think the part # PM102 works
Gotta love those racket wrenches Bouncy
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-18-2008, 01:14 PM   #7
bouncytruck
SKINNY TIRES RULE!
Re: Heater problem
I just stole that picture off the web. I'm not even sure if it's out of our trucks, but it looks similar.
bouncytruck 1972 K5
Old 12-18-2008, 01:43 PM   #8
jaros44sr
jaros44sr's Avatar
Re: Heater problem
Sure looks correct to me, but what do I know...LOL
SAFETY FIRST
AS usual, off topic
Jim
Old 12-19-2008, 06:40 PM   #9
67mater
67mater's Avatar
Re: Heater problem
FYI, pass hood hinge must come off in order to pull the fan and it's still a tricky twist to get the compartment ahead of the core, which is where nesting usually occurs.
Is there air on cold? if not then definitely check that the fan is turning. Might also confir that cables are moving diverters, as you may have a nest AND abroken diverter so the air is always going into the heater core. Basically , take it apart
i would say you can take the front to sections of the inside boxx off relatively easily, and likely tell where your problem is (in fact pulling the rubber cover for the heater cable will let you see if the fan works.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
